Apple MagSafe Power Adapter 60W (MacBook and 13" MacBook Pro)
Quicklinx: 9G3DWS00 Mfr#: MC461B/B
Device Type: Macbook
Type: Power
Device Screen Size: [N/A]
Colour: [N/A]
40 in stock
£62.32 ex VAT
£74.78 inc VAT
The 60 watt MagSafe Power adapter features a magnetic DC connector that ensures your power cable will disconnect if it experiences undue strain and helps prevent fraying or weakening of the cables over time. In addition, the magnetic DC helps guide the plug into the system for a quick and secure connection.
When the connection is secure, an LED located at the head of the DC connector will light up; amber light lets you know that your portable is charging, while a green light tells you that you have a full charge. An AC lead is provided with the adapter for maximum lead length, while the AC wall adapter (also provided) gives users an even easier and more compact way to travel.
Designed to be the perfect traveling companion, the adapter has a clever design that allows the DC cable to be wound neatly around itself for easy cable storage. This power adapter recharges the lithium polymer battery while the system is off, on, or in sleep mode.
Apple MagSafe - power adapter - 60 Watt
Power adapter - external
English / United Kingdom
Power Capacity
60 Watt
Power Capacity
60 Watt
Power cable - integrated
Apple MagSafe Power Adapter 60W (MacBook and 13 Bundle deal on Apple MagSafe Power Adapter 60W (MacBook and 13" MacBook Pro)
£161.49
Type: Power
Colour: [N/A]
Brand: Apple
Price Range Ex VAT: 50 - 100
