Brand
Apple MagSafe Duo Charger - Wireless charging mat
Quicklinx: GHP6WS00 Mfr#: MHXF3ZM/A
Device Type: MagSafe
Type: Wireless Charging
Product Range: Apple
Product Model: MagSafe Duo Charger
More than 50 in stock
£90.84 ex VAT
£109.00 inc VAT
The MagSafe Duo Charger conveniently charges your compatible iPhone, Apple Watch, Wireless Charging Case for AirPods, and other Qi-certified devices. Just place your devices on the charger and a steady, efficient charge begins on contact. The charger folds together neatly so you can easily take it with you wherever you go.
Apple MagSafe Duo Charger wireless charging mat - magnetic
Output Connector Type
Total 2: magnetic
Wireless Charging
Wireless Charging Standards
Qi
Cables
USB-C to Lightning cable - 1 m
1-year warranty
iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 8, 8 Plus, SE (2nd generation), X, XR, XS, XS Max; Watch; AirPods Pro; AirPods with wireless charging case; Wireless Charging Case
Mobile phone, smart watch, wireless earphones
Input Connectors
24 pin USB-C
Output connectors
Total 2: magnetic
Wireless Charging
Qi
Limited warranty - 1 year
Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 8, 8 Plus, SE (2nd generation), X, XR, XS, XS Max , Apple Watch , Apple AirPods Pro , Apple AirPods with wireless charging case , Apple Wireless Charging Case
Brand: Apple
Stock Status: In stock
