Overview
The MagSafe Charger makes wireless charging a snap. The perfectly aligned magnets attach to your iPhone 13, iPhone 13 Pro, iPhone 12 and iPhone 12 Pro, and provide faster wireless charging up to 15W.
The MagSafe Charger maintains compatibility with Qi charging, so it can be used to wirelessly charge your iPhone 8 or later, as well as AirPods models with a wireless charging case, as you would with any Qi-certified charger.
The magnetic alignment experience only applies to iPhone 13, iPhone 13 Pro, iPhone 12 and iPhone 12 Pro models.
Recommended: 20W USB-C Power Adapter (sold separately)
What’s in the Box
- MagSafe Charger
- USB-C integrated cable (1 m)
- Apple MagSafe Charger wireless charging mat - magnetic - 15 Watt
- Product Type
- Wireless charging mat
- Output Connector Type
- Magnetic
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Provided
- 15 Watt
- Cables
- USB-C cable - 1 m
- 1-year warranty
- Designed For
- Apple Wireless Charging Case; AirPods (2nd generation, 3rd generation); AirPods Pro; iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 8, 8 Plus, SE (2nd generation), X, XR, XS, XS Max
- Product Type
- Designed For
- Mobile phone
- Input Connectors
- 24 pin USB-C
- Output connectors
- Magnetic
- Power Provided
- 15 Watt
- Wireless Charging
- Qi
- Cables Included
- USB-C cable - 1 m
- Limited warranty - 1 year
- Designed For
- Apple Wireless Charging Case , Apple AirPods (2nd generation, 3rd generation) , Apple AirPods Pro , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 8, 8 Plus, SE (2nd generation), X, XR, XS, XS Max
