Apple Magic Trackpad 2
Quicklinx: BQ3FWS00 Mfr#: MJ2R2Z/A
Wired / Wireless: Wired, Wireless
Compatibility: Mac
41 in stock
£110.19 ex VAT
£132.22 inc VAT
Redesigned and rechargeable, Magic Trackpad 2 includes a built-in battery and brings Force Touch to the desktop for the first time. Four force sensors underneath the trackpad surface allow you to click anywhere, and detect subtle differences in the amount of pressure you apply, bringing increased functionality to your fingertips and enabling a deeper connection to your content. Magic Trackpad 2 also features an edge-to-edge glass surface area. This design, along with a lower profile, makes scrolling and swiping through your favorite content more productive and comfortable than ever. Magic Trackpad 2 pairs automatically with your Mac, so you can get to work right away. And the battery will power your Magic Trackpad 2 for about a month or more before needing a recharge.
  • More control at your fingertips
    Magic Trackpad gives you a whole new way to control what's on your Mac desktop computer. When you perform gestures, you actually interact with what's on your screen. You feel closer to your content, and moving around feels completely natural. Swiping through pages on screen is just like flipping through pages in a magazine, and inertial scrolling senses the momentum in your fingers as you move up and down a page.
  • More to touch, more to love
    Your fingers will fall for the Magic Trackpad. It's made with smooth, wear-resistant glass that feels great to the touch. And it's nearly 80 percent larger than the built-in trackpad on the MacBook Pro, giving you plenty of room to perform gestures. Because the entire surface of Magic Trackpad is a button, you can click on objects just as you would using a traditional mouse. And Magic Trackpad sits at the same height and angle as the Apple wireless keyboard, so you can go from trackpad to keyboard in one seamless motion.
  • Bluetooth technology
    Magic Trackpad connects to your Mac via Bluetooth wireless technology. Use it in conjunction with the Apple wireless keyboard for a cable-free, uncluttered workspace. And if you feel like venturing away from your desk, Magic Trackpad maintains a reliable and secure connection up to 33 feet away from your Mac.
Apple Magic Trackpad 2 - trackpad - Bluetooth
Trackpad
Wireless, wired - Bluetooth
16 cm x 11.49 cm x 1.09 cm
231 g
Multi-Touch
Force Touch, four sensors
Apple MacOS X 10.11 or later
10.2-inch iPad (7th generation); 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iMac; iMac Pro (Late 2017); iPad Air 2; iPad mini 4; 5; Mac mini; Mac Pro; MacBook; MacBook Air with Retina display; MacBook Pro
Trackpad
16 cm
11.49 cm
1.09 cm
231 g
Input Device
Wireless, wired
Bluetooth
Multi-Touch
Lightning to USB cable
Apple 10.2-inch iPad (7th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 11-inch iPad Pro (1st generation, 2nd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Mid 2017) , Apple iMac Pro (Late 2017) , Apple iPad Air 2 , Apple iPad mini 4 , Apple iPad mini 5 , Apple Mac mini (Early 2020, Late 2014, Late 2018) , Apple Mac Pro (Late 2019, Mid 2012) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air with Retina display (Early 2020, Late 2018, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Mid 2017, Mid 2018, Mid 2019)
Wired / Wireless: Wireless
Compatibility: Mac
Brand: Apple
Stock Status: In stock
