Product
Apple Magic Mouse Wireless
Quicklinx: 69L2WS00 Mfr#: MB829Z/A
1 on order, delivery delayed
The same Multi-Touch technology first introduced on the revolutionary iPhone comes to the mouse. It's called Magic Mouse, and it's the world's first multi-touch mouse. Click anywhere, scroll in any direction, and swipe through images on its smooth, seamless top shell. It works wirelessly using Bluetooth, so you don't have to worry about cables or adapters cluttering your workspace.
  • Magic is in the multi-touch
    The Magic Mouse redefines what a mouse should do. In addition to its smooth, seamless top-shell design that acts as one button or two, Magic Mouse features a multi-touch surface with gesture support. Scroll vertically, horizontally, and diagonally - a full 360 degrees - simply by touching anywhere on the top surface. With a greater surface area for scrolling, you can get around a long timeline in iMovie, through a lengthy web page in Safari, or around a set of images in iPhoto more efficiently. You can also swipe through pages in Safari or photos in iPhoto with two fingers. It's the most advanced Apple mouse ever made.
  • One or two, left or right
    The seamless, one-button design of Magic Mouse makes it simple to use right out of the box. But if you want the functionality of a two-button mouse, that's easy, too. Just change the configuration in system preferences. And the ambidextrous construction means Magic Mouse is great for lefties or righties.
  • Laser tracking engine
    Magic Mouse features a laser tracking engine that's far more sensitive and responsive on more surfaces than traditional optical technology. That means it can track with precision on nearly every surface with no mousepad required.
  • Bluetooth technology
    Magic Mouse works wirelessly with your Bluetooth-enabled Mac. When you combine it with the Apple wireless keyboard, the result is an untethered and uncluttered workspace. Once you pair Magic Mouse with your Mac, you can enjoy a secure and reliable connection from up to 33 feet away.
Apple Magic Mouse - mouse - Bluetooth
Mouse
Wireless - Bluetooth
Orientation
Right and left-handed
Movement Detection Technology
Laser
Multi-touch mouse surface
2 x AA type
iMac; MacBook; MacBook Pro
Mouse
Orientation
Input Device
Wireless
Bluetooth
Laser
AA type
Installed Qty
2
Apple iMac , Apple MacBook , Apple MacBook Pro
