Brand
Apple Magic Mouse and USB-C to Lightning Cable
Quicklinx: GG7HWS00 Mfr#: MK2E3Z/A
Wired / Wireless: Wireless
More than 50 In Stock
£67.48 ex VAT
£80.97 inc VAT
Magic Mouse is wireless and rechargeable, with an optimized foot design that lets it glide smoothly across your desk. The Multi-Touch surface allows you to perform simple gestures such as swiping between web pages and scrolling through documents.
The incredibly long-lasting internal battery will power your Magic Mouse for about a month or more between charges. It's ready to go straight out of the box and pairs automatically with your Mac, and it includes a woven USB-C to Lightning Cable that lets you pair and charge by connecting to a USB-C port on your Mac.
  • Magic is in the multi-touch
    The Magic Mouse redefines what a mouse should do. In addition to its smooth, seamless top-shell design that acts as one button or two, Magic Mouse features a multi-touch surface with gesture support. Scroll vertically, horizontally, and diagonally - a full 360 degrees - simply by touching anywhere on the top surface. With a greater surface area for scrolling, you can get around a long timeline in iMovie, through a lengthy web page in Safari, or around a set of images in iPhoto more efficiently. You can also swipe through pages in Safari or photos in iPhoto with two fingers. It's the most advanced Apple mouse ever made.
  • One or two, left or right
    The seamless, one-button design of Magic Mouse makes it simple to use right out of the box. But if you want the functionality of a two-button mouse, that's easy, too. Just change the configuration in system preferences. And the ambidextrous construction means Magic Mouse is great for lefties or righties.
  • Laser tracking engine
    Magic Mouse features a laser tracking engine that's far more sensitive and responsive on more surfaces than traditional optical technology. That means it can track with precision on nearly every surface with no mousepad required.
  • Bluetooth technology
    Magic Mouse works wirelessly with your Bluetooth-enabled Mac. When you combine it with the Apple wireless keyboard, the result is an untethered and uncluttered workspace. Once you pair Magic Mouse with your Mac, you can enjoy a secure and reliable connection from up to 33 feet away.
Apple Magic Mouse - mouse - Bluetooth
Mouse
Wireless - Bluetooth
5.71 cm x 11.35 cm x 2.16 cm
99 g
Multi-Touch
Scrolling, gesture function, rechargeable battery
Apple MacOS X 10.11 or later, Apple iPadOS 13.4 or later
1-year warranty
11-inch iPad Pro; 12.9-inch iPad Pro; 10.9-inch iPad Air (4th generation); 10.5-inch iPad Air (3rd generation); iPad Air 2; 10.5-inch iPad Pro; 9.7-inch iPad Pro; 10.2-inch iPad; 9.7-inch iPad; iPad mini 4; 5; 6; iMac; iMac Pro; Mac mini; Mac Pro; MacBook; MacBook Air; MacBook Pro
Mouse
5.71 cm
11.35 cm
2.16 cm
99 g
Input Device
Wireless
Bluetooth
Multi-Touch
USB-C to Lightning cable
Limited warranty - 1 year
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Early 2021, Late 2014, Late 2015, Mid 2015, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad Air 2 , Apple iPad mini (6th generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple Mac mini (Early 2020, Late 2014, Late 2018, Late 2020) , Apple Mac Pro (Late 2013, Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2015, Early 2020, Late 2018, Late 2020, Mid 2017, Mid 2019) , Apple MacBook Pro (Early 2013, Early 2015, Early 2020, Late 2012, Late 2013, Late 2016, Late 2019, Late 2020, Late 2021, Mid 2012, Mid 2014, Mid 2015, Mid 2017, Mid 2018, Mid 2019)
Brand: Apple
