Apple Magic Mouse 2
Apple Magic Mouse 2
Quicklinx: BQBXWS00 Mfr#: MLA02Z/A
Wired / Wireless: Wireless
Compatibility: Mac
£54.56 ex VAT
£65.47 inc VAT
Featuring impressive design, Magic Mouse 2 is completely rechargeable, so you'll eliminate the use of traditional batteries. It's lighter, has fewer moving parts thanks to its built-in battery and continuous bottom shell, and has an optimized foot design - all helping Magic Mouse 2 track easier and move with less resistance across your desk. And the multi-touch surface allows you to perform simple gestures such as swiping between web pages and scrolling through documents. Magic Mouse 2 is ready to go right out of the box and pairs automatically with your Mac.
  • Magic is in the multi-touch
    The Magic Mouse redefines what a mouse should do. In addition to its smooth, seamless top-shell design that acts as one button or two, Magic Mouse features a multi-touch surface with gesture support. Scroll vertically, horizontally, and diagonally - a full 360 degrees - simply by touching anywhere on the top surface. With a greater surface area for scrolling, you can get around a long timeline in iMovie, through a lengthy web page in Safari, or around a set of images in iPhoto more efficiently. You can also swipe through pages in Safari or photos in iPhoto with two fingers. It's the most advanced Apple mouse ever made.
  • One or two, left or right
    The seamless, one-button design of Magic Mouse makes it simple to use right out of the box. But if you want the functionality of a two-button mouse, that's easy, too. Just change the configuration in system preferences. And the ambidextrous construction means Magic Mouse is great for lefties or righties.
  • Laser tracking engine
    Magic Mouse features a laser tracking engine that's far more sensitive and responsive on more surfaces than traditional optical technology. That means it can track with precision on nearly every surface with no mousepad required.
  • Bluetooth technology
    Magic Mouse works wirelessly with your Bluetooth-enabled Mac. When you combine it with the Apple wireless keyboard, the result is an untethered and uncluttered workspace. Once you pair Magic Mouse with your Mac, you can enjoy a secure and reliable connection from up to 33 feet away.
Apple Magic Mouse 2 - mouse - Bluetooth
Mouse
Wireless - Bluetooth
5.71 cm x 11.35 cm x 2.16 cm
99 g
Multi-Touch
Scrolling, gesture function
Apple MacOS X 10.11 or later
10.2-inch iPad (7th generation); 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iMac; iMac Pro; iPad Air 2; iPad mini 4; 5; Mac mini; Mac Pro (Late 2019); MacBook; MacBook Air with Retina display; MacBook Pro
Mouse
5.71 cm
11.35 cm
2.16 cm
99 g
Input Device
Wireless
Bluetooth
Multi-Touch
Lightning to USB cable
Apple 10.2-inch iPad (7th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 11-inch iPad Pro (1st generation, 2nd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Mid 2017) , Apple iMac Pro (Early 2019, Late 2017) , Apple iPad Air 2 , Apple iPad mini 4 , Apple iPad mini 5 , Apple Mac mini (Early 2020, Late 2018) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air with Retina display (Early 2020, Late 2018, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Mid 2017, Mid 2018, Mid 2019)
Compatibility: Mac
Brand: Apple
Price Range Ex VAT: 50 - 100
