The goal with MacBook was to do the impossible: engineer a full-size experience into a light and compact Mac notebook. That meant reimagining every element to make it not only lighter and thinner but also better. The result is more than just a notebook. It’s the future of the notebook. And now, with powerful processors, improved graphics performance, faster flash storage, and long battery life, MacBook is even more capable.
A full-size keyboard
A comfortable, full-size keyboard is essential for a great notebook experience. To create the keyboard, each key and its underlying mechanism have been redesigned - not only making the whole keyboard much thinner, but also allowing for more comfortable, precise, and responsive typing that just feels right. -
Retina re-envisioned
The moment you open the MacBook, its gorgeous 12-inch Retina display with edge-to-edge glass brings everything into focus. Every photo leaps off the screen in rich, vibrant detail. Over 3 million pixels render each letter with crystal clarity. And it all comes to light on the thinnest, most energy-efficient Retina display ever on a Mac, meticulously honed to deliver a bold visual experience within an impossibly minimal design. -
The trackpad, pushed even further with Force Touch
The Force Touch trackpad is engineered to deliver a responsive, uniform click no matter where you press the surface. And underneath, force sensors detect how much pressure you're applying and give you convenient ways to interact with your Mac. You can use a Force click to enable new capabilities, like quickly looking up the definition of a word or previewing a file just by clicking and continuing to press on the trackpad. You'll also experience haptic feedback - a tactile vibration from the trackpad that adds the sense of touch to what you see on the screen. These advanced capabilities work in addition to all the intuitive Multi-Touch gestures Mac users love. You'll be more in touch with your Mac than ever before. Without lifting a finger. -
Fully equipped for a wireless world
The MacBook is designed to fit effortlessly into an increasingly wireless world. Just about anything you do with a notebook can now be done over the air, thanks to Apple software that takes full advantage of Wi-Fi and Bluetooth wireless technology. So no matter where you are, you can connect to the web, transfer files, organize your photos, listen to music, and more - without being tied down. -
Quietly astonishing
The MacBook has been engineered from the ground up for silent, efficient performance. It starts with a powerful Intel Core processor that runs on low power, made even more efficient by optimizations throughout OS X Yosemite. Together the processor and OS X sip so little energy that the system generates very little heat, so no fan is required to cool the computer. That means when your MacBook is working, you won't hear a thing. And the logic board on which the processor sits has been completely redesigned to pack all the capability you expect in a Mac into as little space as possible. -
All-day battery life
People rely on Apple notebooks for all-day battery life, regardless of how compact they are. And with the slim MacBook enclosure, all-day battery life simply would not be achievable using traditional rectangular batteries. The unique battery technology was specifically designed to make use of every last millimeter of available space. The result is a terraced, contoured battery design that not only fits perfectly inside the incredibly slim MacBook, but also is unlike anything seen before in a notebook.
- Apple MacBook - 12" - Intel Core m5 - 8 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Catalina 10.15
- Processor
- Intel Core m5 1.2 GHz, up to 2.7 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 12" LED backlight 2304 x 1440 - 226 ppi
- Graphics
- Intel HD Graphics 515
- Input Device
- Force Touch trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- Up to 11 hours
- Silver
- 28.05 cm x 19.65 cm x 1.31 cm
- 920 g
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Specific Absorption Rate (SAR)
- 0.233 W/kg (body)
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Catalina 10.15
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Integrated memory controller, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 512 GB SSD
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2304 x 1440
- Widescreen
- Pixel Density (ppi)
- 226
- Image Aspect Ratio
- 16:10
- BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free
Audio & Video
- Graphics Processor
- Camera
- Yes - 480p
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, Force Touch trackpad
- Keyboard Layout
- UK
- Multi-touch touchpad, ambient light sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 41.4 Wh
- Run Time
- Up to 11 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 11 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 29 Watt
Connections & Expansion
- Interfaces Details
- USB-C 3.1 Gen 1 (supports DisplayPort 1.2 Alt Mode) , Headphone output
Software
- Software Included
- iTunes, Apple QuickTime, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Mail, Maps, Photos, Reminders, App Store, Contacts, Notes, Calendar, Messages, Game Center, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
- Silver
- Case Material
- Aluminum
- Included Accessories
- USB-C power adapter
- Cables Included
- USB-C charge cable
- SAR Value
- 0.233 W/kg (body)
- 0.233 W/kg (body)
- Localization
- 920 g
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
