The goal with MacBook was to do the impossible: engineer a full-size experience into a light and compact Mac notebook. That meant reimagining every element to make it not only lighter and thinner but also better. The result is more than just a notebook. It’s the future of the notebook. And now, with powerful processors, improved graphics performance, faster flash storage, and long battery life, MacBook is even more capable.
A Retina display that takes everything to the edge
The moment you open your MacBook, its gorgeous 12-inch Retina display with edge-to-edge glass brings everything into focus. Every photo leaps off the screen in rich, vibrant detail. Over 3 million pixels render each letter with crystal clarity. And it all comes to light on a thin Retina display, meticulously honed to deliver a bold visual experience within an impossibly minimal design. -
The trackpad, pushed even further with Force Touch
MacBook comes with a different way to experience a trackpad. The Force Touch trackpad is engineered to deliver a responsive, uniform click no matter where you press the surface. And underneath, force sensors detect how much pressure you're applying. You can now use a Force click to enable useful capabilities, like quickly looking up the definition of a word or previewing a file just by clicking and continuing to press the trackpad. You'll also experience haptic feedback - a tactile vibration from the trackpad that adds the sense of touch to what you see on the screen. These advanced capabilities work in addition to all the intuitive Multi-Touch gestures Mac users love. You'll be more in touch with your Mac than ever before. Without lifting a finger. -
Fully equipped for a wireless world
MacBook is designed to fit effortlessly into an increasingly wireless world. Just about anything you do with a notebook can now be done over the air, thanks to Apple software that takes full advantage of the latest Wi-Fi and Bluetooth wireless technology. So no matter where you are, you can connect to the web, transfer files, organize your photos, listen to music, and more - without being tied down. -
USB-C - singularly versatile
The USB-C port puts just about everything you need in a port all in one place. This amazing port provides charging, speedy USB 3 data transfer, and video output in a reversible design that's one-third the size of a USB 3 port, giving you the flexibility to easily connect your favorite devices. -
The capability to connect to everything you need
USB-C lets you connect your charger; HDMI, DisplayPort, and VGA displays; USB devices like external drives; and your iPhone or iPad. All of which goes to show that sometimes less really is more. -
Quietly astonishing
MacBook has been engineered from the ground up for silent, efficient performance. It includes sixth-generation Intel Core M processors that run on just 5 watts of power, made even more efficient by optimizations throughout OS X. Together the processor and OS X sip so little energy that the system generates very little heat, so no fan is required to cool the computer. That means when your MacBook is working, you won't hear a thing. And the logic board on which the processor sits has been painstakingly engineered to pack all the capability you expect in a Mac into as little space as possible. -
Built-in Apps
The Mac comes with apps for creativity and apps for productivity. It also comes with a collection of great apps for things you do every day, like sur?ng the web, sending mail and messages, and organizing your calendar. It even comes with an app for finding new apps. Your Mac is more than full-featured, it's fully loaded. -
Precision backlighting
The LEDs are calibrated for uniform brightness, so every key and character looks clear and sharp with minimal light around the keycap. All while being engineered for as much energy efficiency as possible. -
AirDrop - sharing files has never been easier
AirDrop makes sharing files with another Mac or an iOS device simple. With just a few clicks, you can take a file from any folder and use AirDrop to send it directly to a nearby Mac or iOS device. No need to email it or use any other web-based service. It's a simple way to share a great photo on your Mac to your friend's iPhone. Or send your contact info to a new colleague across the table. -
Wireless wherever you go
If you're out of Wi-Fi range, your MacBook can connect to the Personal Hotspot on your iPhone by using its cellular connection when it's close by. So even when you're far away from a Wi-Fi connection, using your MacBook to browse the web and send email is still well within reach. With the Instant Hotspot feature, you'll see the name of your iPhone in the list of Wi-Fi networks on your MacBook. Just select it and you're connected. And when you're not using your phone's network, your devices intelligently disconnect to save battery life. -
Time Machine - automatic wireless backup
Time Machine makes it simple to keep everything on your Mac backed up wirelessly to an AirPort Time Capsule or other external hard drive connected to an AirPort base station. Time Machine automatically backs up your data while you're connected to your Wi-Fi network, so you don't have to remember to do it. When it's this easy to back up everything, you won't have to worry about anything.
- Apple MacBook - 12" - Intel Core m5 - 8 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Catalina 10.15
- Processor
- Intel Core m5 1.2 GHz, up to 2.7 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 12" LED backlight 2304 x 1440 - 226 ppi
- Graphics
- Intel HD Graphics 515
- Input Device
- Force Touch trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- Up to 11 hours
- Gold
- 28.05 cm x 19.65 cm x 1.31 cm
- 920 g
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Specific Absorption Rate (SAR)
- 0.233 W/kg (body)
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Catalina 10.15
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Integrated memory controller, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 512 GB SSD
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2304 x 1440
- Widescreen
- Pixel Density (ppi)
- 226
- Image Aspect Ratio
- 16:10
- BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free
Audio & Video
- Graphics Processor
- Camera
- Yes - 480p
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, Force Touch trackpad
- Keyboard Layout
- UK
- Multi-touch touchpad, ambient light sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 41.4 Wh
- Run Time
- Up to 11 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 11 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 29 Watt
Connections & Expansion
- Interfaces Details
- USB-C 3.1 Gen 1 (supports DisplayPort 1.2 Alt Mode) , Headphone output
Software
- Software Included
- Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iPhoto, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Apple Spotlight, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, Facebook, Twitter
- Gold
- Case Material
- Aluminum
- Included Accessories
- USB-C power adapter
- Cables Included
- USB-C charge cable
- SAR Value
- 0.233 W/kg (body)
- 0.233 W/kg (body)
- Localization
- 920 g
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
