The goal with MacBook was to do the impossible: engineer a full-size experience into a light and compact Mac notebook. That meant reimagining every element to make it not only lighter and thinner but also better. The result is more than just a notebook. It’s the future of the notebook. And now, with powerful processors, improved graphics performance, faster flash storage, and long battery life, MacBook is even more capable.
All-day battery life
With the slim MacBook enclosure, all-day battery life simply would not be achievable using traditional rectangular batteries. So Apple developed its own battery technology specifically designed to make use of every last millimeter of available space. The result is a terraced, contoured battery design that not only fits perfectly inside the incredibly slim MacBook, but also is unlike anything seen before in a notebook. And now, thanks to more efficient processors and improved battery chemistry, battery life has been extended by an hour. -
Quietly astonishing
MacBook has been engineered from the ground up for silent, efficient performance. It includes an Intel Core M processor that runs on just 5 watts of power, made even more efficient by optimizations throughout OS X. Together the processor and OS X sip so little energy that the system generates very little heat, so no fan is required to cool the computer. That means when your MacBook is working, you won't hear a thing. And the logic board on which the processor sits has been painstakingly engineered to pack all the capability you expect in a Mac into as little space as possible. -
3 million pixels, 0.88 millimeter - razor sharp
The 12-inch Retina display on the MacBook isn't just picture perfect - it's also paper thin. A specially developed automated manufacturing process forms the impossibly thin edge-to-edge glass that's only 0.5 millimeter thick. And the space between display components has been reduced for a tighter, more integrated design. To deliver the gorgeous Retina experience, Apple's engineers had to innovate on every level, right down to the pixel. So they redesigned the pixels to create a larger aperture, allowing more light to pass through. -
Optimized for energy efficiency
Each aspect of your MacBook - from the Retina display to the terraced battery to the advanced technologies of OS X - has been optimized to be as energy efficient as possible. It also exceeds the low power requirements set by the EPA, giving it ENERGY STAR 6.1 qualification. And because the MacBook battery requires less frequent charging, it leaves a smaller carbon footprint from day-to-day use. -
USB-C - singularly versatile
The USB-C port puts just about everything you need in a port all in one place. This amazing port provides charging, speedy USB 3 data transfer, and video output in a reversible design that's one-third the size of a USB 3 port, giving you the flexibility to easily connect your favorite devices. -
Force Touch trackpad
The Force Touch trackpad may look like other trackpads on the surface, but underneath it's unlike anything that's existed before. Force sensors detect how much pressure you're applying, and the Taptic Engine provides a click sensation when you press anywhere on the surface. Now the click that once was a single, mechanical function is just the start of what you can do with Force Touch. The sensory capabilities of the Force Touch trackpad allow you to tell your MacBook what you want it to do based on subtle differences in the amount of pressure you apply. This makes it possible to perform a variety of different actions in different apps, all on the same surface. And it can respond with haptic feedback you can actually feel, making your MacBook more usable and personal than ever before.
- Apple MacBook - 12" - Intel Core m3 - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Sierra 10.12
- Processor
- Intel Core m3 1.1 GHz, up to 2.2 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 12" LED backlight 2304 x 1440 - 226 ppi
- Graphics
- Intel HD Graphics 515
- Input Device
- Force Touch trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- Up to 11 hours
- Silver
- 28.05 cm x 19.65 cm x 1.31 cm
- 920 g
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Specific Absorption Rate (SAR)
- 0.233 W/kg (body)
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Sierra 10.12
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.2 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Integrated memory controller, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2304 x 1440
- Widescreen
- Pixel Density (ppi)
- 226
- Image Aspect Ratio
- 16:10
- BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free
Audio & Video
- Graphics Processor
- Camera
- Yes - 480p
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, Force Touch trackpad
- Keyboard Layout
- UK
- Multi-touch touchpad, ambient light sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 41.4 Wh
- Run Time
- Up to 11 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 11 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 29 Watt
Connections & Expansion
- Interfaces Details
- USB-C , Headphone output
Software
- Software Included
- iTunes, Apple QuickTime, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Mail, Maps, Photos, Reminders, App Store, Contacts, Notes, Calendar, Messages, Game Center, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
- Silver
- Case Material
- Aluminum
- Included Accessories
- USB-C power adapter
- Cables Included
- USB-C charge cable
- SAR Value
- 0.233 W/kg (body)
- 0.233 W/kg (body)
- Localization
- 920 g
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
