A groundbreaking Retina display. A force-sensing trackpad. All-flash architecture. Powerful processors. Together, these features take the notebook to a high performance. And they will do the same for you in everything you create.
When you pack so many pixels into a display the results are positively stunning. The pixel density is so high, your eyes can’t discern individual pixels. Images take on a new level of realism. A spectacular resolution lets you see more of your high-resolution images with pixel-for-pixel accuracy. And text is so sharp, you’ll feel like you're reading email, web pages, and documents on a printed page.
The Retina display reduces glare while maintaining incredible color and quality. Its high contrast ratio results in blacker blacks and whiter whites. And everything in between is rich and vibrant. IPS technology gives you a wide, 178-degree view of everything on the screen, so you'll see the difference at practically any angle. And you're going to love what you see.
Press a little deeper, do a lot more
With Multi-Touch in OS X, you can use realistic gestures like swiping or pinching to switch between apps, navigate your content, and get the most out of your desktop space. The Force Touch trackpad takes all the capabilities of Multi-Touch and adds force sensors that detect subtle differences in the amount of downward pressure you apply. This lets you have a deeper connection to your content, bringing more functionality right to your fingertip. It also introduces haptic feedback to MacBook Pro - allowing you not just to see what's happening on the screen, but to feel it. -
Longer-lasting battery holding up to a 9-hour charge
That's impressive battery life for any notebook. But for a high-performance notebook with an ultra-high-resolution display, state-of-the-art processors and graphics, and a super slim design, it's absolutely remarkable. The built-in battery gives you up to 1000 full charge and discharge cycles. -
Faster flash storage
Thanks to the superfast read and write performance of the PCle-based flash storage, you'll notice a difference in whatever you do. Starting up is really fast, apps launch quickly, and navigating the desktop feels fluid and responsive. In addition, flash has no moving parts, so it's super durable and quiet. -
The definition of fast
Meet the ultimate mobile creative studio - with the emphasis on mobile. Equipped with 802.11ac Wi-Fi and Bluetooth 4.0 wireless technology, you're free to unplug and still stay connected - to your network, to your wireless peripherals, and to the world. -
Stereo speakers
You haven't heard it all until you've heard the speakers inside MacBook Pro. For something so thin and light, the sound is huge. And with a wide dynamic range, optimal balance, and a crisp, expressive quality, these speakers might sound too good to be true. -
Dual microphones
Dual built-in microphones are great for when you want to be heard. If you're making a FaceTime call, for example, the mics reduce background noise from behind the notebook. And when you use Dictation, they create an adaptive audio beam that intelligently adjusts to detect your voice - instead of the noise around you. -
FaceTime HD camera
Make your point with greater clarity. Centered just above the widescreen Retina display on MacBook Pro is an advanced FaceTime HD camera, with an image sensor that produces accurate colors and reduced image noise even in low light. The sophisticated image processor produces sharper images and reduced motion blur. And the face detection feature automatically adjusts exposure and white balance to complement your face and skin tone, so you always look your best - no matter what lighting is behind you.
- Apple MacBook Pro with Retina display - 15.4" - Intel Core i7 - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Catalina 10.15
- Processor
- Intel Core i7 (4th Gen) - 2.5 GHz, up to 3.7 GHz / 6 MB Cache
- Memory
- 16 GB DDR3L (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 15.4" LED backlight 2880 x 1800
- Graphics
- AMD Radeon R9 M370X / Intel Iris Pro Graphics
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- Force Touch trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- Up to 9 hours
- 35.89 cm x 24.71 cm x 1.8 cm
- 2.02 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Specific Absorption Rate (SAR)
- 0.274 W/kg (body)
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Catalina 10.15
Processor / Chipset
- CPU
- Intel Core i7 (4th Gen) 2.5 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Integrated memory controller, Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 512 GB SSD
Display
- 15.4" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2880 x 1800
- Widescreen
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, Force Touch trackpad
- Keyboard Layout
- UK
- Multi-touch touchpad, ambient light sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 99.5 Wh
- Run Time
- Up to 9 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 9 hours , Video playback: up to 9 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 85 Watt
Connections & Expansion
- 2 x USB 3.0 , 2 x Thunderbolt 2 , HDMI , Headphone output
- Memory Card Reader
- Yes (SDXC Card)
Software
- Software Included
- Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
- Case Material
- Aluminum
- Included Accessories
- Power adapter
- SAR Value
- 0.274 W/kg (body)
- 0.274 W/kg (body)
- Localization
- 2.02 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
