Apple MacBook Pro 13" 2.3GHz dual-core i5 256GB - Space Grey
Quicklinx: CXYFWS00 Mfr#: MPXT2B/A
Colours:
  • Core i5
  • IEEE 802.11n
It's razor-thin, feather-light, and even faster and more powerful than before. It has the extremely bright, colorful Mac notebook display. MacBook Pro is built on groundbreaking ideas. And it's ready for yours.
  • Speed-of-the-art
    MacBook Pro elevates the notebook to another level of performance and portability. Wherever your ideas take you, you'll get there faster than ever with excellent graphics, high-performance processors, whip-smart storage, and more.
  • Eye-opening graphics performance
    The MacBook Pro features a powerful discrete GPU. Manufactured with an improved process, the graphics combine outstanding power with outstanding power efficiency. And now generous memory comes standard, giving you fluid, real-time performance for pro tasks, like rendering 3D titles in Final Cut Pro X. Every model features powerful integrated graphics with generous embedded memory, which accelerates graphics tasks. That means more time for what matters more - creating amazing work.
  • Speedy hard drive storage - snap to everything
    MacBook Pro boasts a fast hard drive, that's blazing fast, with high sequential read speeds. There is enough space to take even your big projects with you, without having to take an external drive. And its memory is both high-speed and power-efficient. It all works together to help you boot up, launch multiple apps, or import huge files in a flash.
  • Processors, that provide incredible power - and use incredibly little
    With powerful processor, MacBook Pro delivers amazing performance, with Turbo Boost frequencies. So you can move fast - even when powering through pro-level processing jobs, like rendering 3D models and encoding video. At the same time, it can conserve energy when taking on lighter tasks, like browsing the web and checking email. And 10-bit HEVC hardware acceleration comes standard on MacBook Pro, which will let you take even more advantage of the boosts in 4K video compression and streaming performance.
  • Impressive all-day battery life
    MacBook Pro packs more performance into a thin design, yet still provides all-day battery life. So you're free to keep watching, gaming, and editing from wherever you are.
  • The extremely cool thing
    The thinner the notebook, the less space for cooling. So MacBook Pro incorporates innovations throughout the system, that efficiently eliminate heat - increasing airflow during intensive tasks, like editing video, playing graphics-heavy games, and transferring huge files.
  • The amazingly bright, colorful Mac notebook display
    The display in the MacBook Pro features bright LED backlighting and a high contrast ratio, delivering deep blacks and bright whites. Its large pixel aperture and variable refresh rate make it power-efficient. And it supports wide color for even more vibrant greens and reds than with sRGB. This makes for more true-to-life pictures with realistically vivid details - essential for graphic design, color grading, and editing.
  • Speakers, that speak for themselves - loudly
    Enjoy beautifully balanced, high-fidelity sound, that takes listening to another levels with wide dynamic range and more bass for maximum boom. The speakers are connected directly to system power, enabling greater peak amplification. So they make MacBook Pro the perfect choice for mixing a track on the fly, editing video on location, or enjoying a movie on the go.
  • More responsive keyboard, more expansive trackpad
    Interacting with MacBook Pro is a smooth experience all around. The keyboard features the improved butterfly mechanism - providing more key stability, along with greater comfort and responsiveness. And the spacious Force Touch trackpad gives your fingers plenty of room to gesture and click.
  • The extremely powerful and versatile port
    Thunderbolt 3 combines ultra-high bandwidth with the ultra-versatility of the USB-C industry standard to create one revved-up universal port. It integrates data transfer, charging, and video output in a single connector, delivering fast throughput for more bandwidth. MacBook Pro features four ports, so you can do all that from either side. Existing devices are easily connected with a cable or adapter. And Thunderbolt 3 is reversible, so no matter how you plug in, it's always right side up.
Apple MacBook Pro with Retina display - 13.3" - Core i5 - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Apple macOS Mojave 10.14
Intel Core i5 (7th Gen) 2.3 GHz (3.6 GHz)
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
13.3" LED backlight 2560 x 1600 / WQXGA
Graphics
Intel Iris Plus Graphics 640
Input Device
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 10 hours
Space grey
30.41 cm x 21.24 cm x 1.49 cm
1.37 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Dual-Core
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Storage
Main Storage
256 GB SSD - (soldered) PCIe
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
2560 x 1600 (WQXGA)
Widescreen
Image Brightness
500 cd/m²
Wide Colour Gamut
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
FaceTime HD camera
Sound
Stereo speakers, two microphones
Input
Keyboard, Force Touch trackpad
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, 12 function keys
Communications
Wireless
Lithium polymer
54.5 Wh
Run Time
Up to 10 hours
Battery Run Time
Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 10 hours , Standby time: up to 30 days
AC Adapter
Input
Output
61 Watt
Connections & Expansion
2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort , Headphone output
Software
Software Included
Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Siri, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
Space grey
Case Material
Aluminum
USB-C power adapter
USB-C charge cable
Localization
1.37 kg
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
