Apple Lightning to VGA Adapter
Quicklinx: 8HTHWS00 Mfr#: MD825ZM/A
More than 50 in stock
£37.16 ex VAT
£44.59 inc VAT
Use the Lightning to VGA Adapter to mirror whatever's on your iPhone, iPad, or iPod touch with Lightning connector - apps, presentations, websites, and more - on your VGA-equipped TV, display, projector, or other compatible display in up to 720p HD. Video mirroring is supported on all compatible devices.
Watch video on the big screen in up to 1080p by connecting your device with a Lightning connector to a television, projector, or other VGA-compatible display. Video out supports up to 1080p for iPad mini, iPad with Retina display, iPhone 5, and iPod touch.
The Lightning to VGA Adapter connects to your iPad with Retina display, iPad mini, iPhone 5, or iPod touch via the lightning connector and to your projector or display using the VGA adapter.
Apple adapter cable
Cable
Adapter cable - VGA
Max Output Resolution
1920 x 1080
Connector
Lightning - male
Connector (Second End)
DB-15 - female
10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; 5; iPad with Retina display; iPhone 11, 12, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max; iPod touch
Cable Type
Adapter cable
Interface Supported
VGA
Adapters & Converters
1920 x 1080
Connector
Apple Lightning - male
15 pin D-Sub (DB-15) - female
Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini (1st generation) , Apple iPad mini 2 (2nd generation) , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod touch (6G, 7G)
Brand: Apple
Stock Status: In stock
