This USB 2.0 cable connects your iPhone, iPad, or iPod with lightning connector to your computer's USB port for syncing and charging or to the Apple USB power adapter for convenient charging from a wall outlet.
- Apple Lightning cable - Lightning / USB - 50 cm
- Cable
- Lightning cable - Lightning / USB
- Length
- 50 cm
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Designed For
- 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X; iPod nano (7G); iPod touch (5G, 6G)
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Length
- 50 cm
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- Designed For
- Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X , Apple iPod nano (7G) , Apple iPod touch (5G, 6G)
