Apple Lightning to USB Cable (0.5m)
Quicklinx: 90CLWS00 Mfr#: ME291ZM/A
Length: 50cm
More than 50 in stock
£18.75 ex VAT
£22.50 inc VAT
This USB 2.0 cable connects your iPhone, iPad, or iPod with lightning connector to your computer's USB port for syncing and charging or to the Apple USB power adapter for convenient charging from a wall outlet.
Apple Lightning cable - 50 cm
Cable
Lightning cable - Lightning / USB
Length
50 cm
Connector
Lightning - male
Connector (Second End)
USB - male
Apple Wireless Charging Case; 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; AirPods; AirPods Max; AirPods Pro; iPad Air 2; iPad mini; iPad mini 2; 4; 5; iPad with Retina display; iPhone 11, 12, 5c, 6s, 7, 8, SE, X, XR, XS, XS Max
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Length
50 cm
Connector
Apple Lightning - male
4 pin USB Type A - male
Apple Wireless Charging Case , Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple AirPods , Apple AirPods Max , Apple AirPods Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod nano (7G) , Apple iPod touch (5G, 6G, 7G)
Length: 50cm
Brand: Apple
Stock Status: In stock
