Apple Lightning to USB-C Cable (1M)
Quicklinx: DRYHWS00 Mfr#: MQGJ2ZM/A
Connect your iPhone, iPad or iPod with Lightning connector to your USB-C– or Thunderbolt 3 (USB-C)–enabled Mac for syncing and charging.
You can also use this cable with your Apple 29W, 30W, 61W or 87W USB-C Power Adapter to charge your iOS device, and even take advantage of the fast-charging feature on iPhone 8, iPhone 8 Plus, iPhone X and selected iPad Pro models.
Compatible with the following computers:
12-inch MacBook, 13-inch MacBook Pro - Thunderbolt 3 (USB-C), 15-inch MacBook Pro - Thunderbolt 3 (USB-C), 21.5-inch iMac - Thunderbolt 3 (USB-C), 27-inch iMac - Thunderbolt 3 (USB-C); iMac Pro
Apple Lightning cable - Lightning / USB - 1 m
Cable
Length
1 m
White
Connector
Lightning - male
Connector (Second End)
24 pin USB-C - male
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Length
1 m
White
Connector
Apple Lightning - male
24 pin USB-C - male
