Apple Lightning to USB 3 Camera Adapter
Quicklinx: CCS8WS00 Mfr#: MK0W2ZM/A
£28.96 ex VAT
£34.75 inc VAT
With the Lightning to USB 3 Camera Adapter, it's easy to transfer photos and videos from your high-resolution digital camera to your iPad. Add even greater capability and versatility to your iPad by powering the Lightning to USB 3 Camera Adapter with USB power adapter. Then you can connect USB peripherals like hubs, Ethernet adapters, audio/MIDI interfaces, and card readers for CompactFlash, SD, microSD and more. The Lightning to USB 3 Camera Adapter supports standard photo formats.
Apple Lightning to USB 3 Camera Adapter - Lightning adapter
Cable
Lightning adapter - Lightning / USB
Connectors
Lightning - male
Connectors (Second End)
USB - female , Lightning - female
10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; 5; iPad with Retina display; iPhone 11, 12, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max
Cable Type
Lightning adapter
Interface Supported
Lightning / USB
Connectors
Apple Lightning - male
4 pin USB Type A - female , Apple Lightning - female
Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max
Brand: Apple
Stock Status: In stock
