Apple Lightning Digital AV Adapter
Quicklinx: 8JKSWS00 Mfr#: MD826ZM/A
46 in stock
£47.60 ex VAT
£57.12 inc VAT
Use the Lightning Digital AV Adapter to mirror whatever's on your iPad with Retina display, iPad mini, iPhone 5, and iPod touch (5th generation) with Lightning connector - apps, presentations, websites, slideshows, and more - on your HDMI-equipped TV, display, projector, or other compatible display in up to 720p HD. Video mirroring is supported on all compatible devices.
Watch video on the big screen in up to 1080p by connecting your device with Lightning connector to a television, projector, or other HDMI-compatible display. Video out supports up to 1080p for iPad mini, iPad with Retina display, iPhone 5, and iPod touch (5th generation).
The Lightning Digital AV Adapter connects to your iPad with Retina display, iPad mini, iPhone 5, or iPod touch (5th generation) via the Lightning connector and to your projector or display using the digital AV adapter.
Apple Lightning Digital AV Adapter - Lightning cable
Cable
Lightning cable - HDMI / Lightning
Connectors
Lightning - male
Connectors (Second End)
HDMI - female , Lightning - female
10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; 5; iPad with Retina display; iPhone 11, 12, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max; iPod touch
Cable Type
Lightning cable
Interface Supported
HDMI / Lightning
Connectors
Apple Lightning - male
19 pin HDMI Type A - female , Apple Lightning - female
Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod touch (6G, 7G)
Brand: Apple
Stock Status: In stock
