Apple iPod shuffle 2GB - Space Gray
Quicklinx: BHZ5WS00 Mfr#: MKMJ2BT/A
Colours:
Even the iPod shuffle clip gets the rock star treatment. Now forged in stainless steel, the clip attaches securely to your shirt, jacket, workout gear, even your backpack. And the sleek, durable, anodized aluminum case - makes iPod shuffle a wardrobe essential.
You've probably made multiple playlists in iTunes. With the iPod shuffle, you can sync your playlists and always find the perfect mix for your activity or mood. VoiceOver tells you the name of each playlist, so it's easy to switch between them and find the one you want without looking.
The shuffle switch has three positions. Flip it to the left, and your music shuffles for a "whatever happens, happens" flow. Flip it to the middle, and your songs play in order. Or flip to the right to turn it off.
  • Easy access controls
    The controls of the iPod shuffle are located on the right earbud cord. With command central now strategically placed in this more convenient location, you can navigate your music - and activate the VoiceOver feature - without taking your eyes off your run, your ride, or whatever you're doing.
  • Fashion tech-cessory
  • Multiple playlists
  • Multi-music-lingual
    Your music library has songs from all over the world. That's why VoiceOver speaks 14 different languages. So it can tell you song titles and artists in the correct languages.
  • Shuffle, straight, stop
Apple iPod shuffle - digital player
Digital player flash based
Enclosure Colour
Space grey
3.16 cm x 0.87 cm x 2.9 cm
12.5 g
Playback Digital Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, Audible AAX, Audible AAX+, protected AAC
Sound Output Mode
Stereo
iPod Generation
4G
Audio Specifications
Digital Player - response bandwidth: 20 - 20000 Hz
Internal Memory
2 GB
Headphones
Headphones - binaural - ear-bud - stereo
Rechargeable - Lithium Ion
1-year warranty
Digital player
Digital Player Type
Flash based
Enclosure Colour
Space grey
Enclosure Material
Aluminium
Audio Formats
iPod Generation
4G
Audio System
Internal Memory
2 GB
File System Supported
2 GB
Sound Output Mode
Stereo
Functions
Digital player
Digital Player - response time: 20 - 20000 Hz
USB 2.0 compatibility, VoiceOver, built-in clip
Digital Player (Recorder)
Supported Bit Rate
8 - 320Kbps
Variable bit-rate compatible
Headphones
Headphones Type
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Connector Type
Headphones (mini-phone stereo 3.5 mm)
USB adapter cable, Apple EarPods
Integrated Battery
Run Time (Up To)
15 hour(s)
Microsoft Windows 7 or later, Apple MacOS X 10.7.5 or later
Software Requirements
iTunes 12.2 or later
Additional Requirements
USB port (compatible with 2.0 specification)
Limited warranty - 1 year , Technical support - phone consulting - 90 days
3.16 cm
0.87 cm
2.9 cm
12.5 g
