Even the iPod shuffle clip gets the rock star treatment. Now forged in stainless steel, the clip attaches securely to your shirt, jacket, workout gear, even your backpack. And the sleek, durable, anodized aluminum case - makes iPod shuffle a wardrobe essential.
You've probably made multiple playlists in iTunes. With the iPod shuffle, you can sync your playlists and always find the perfect mix for your activity or mood. VoiceOver tells you the name of each playlist, so it's easy to switch between them and find the one you want without looking.
The shuffle switch has three positions. Flip it to the left, and your music shuffles for a "whatever happens, happens" flow. Flip it to the middle, and your songs play in order. Or flip to the right to turn it off.
Easy access controls
The controls of the iPod shuffle are located on the right earbud cord. With command central now strategically placed in this more convenient location, you can navigate your music - and activate the VoiceOver feature - without taking your eyes off your run, your ride, or whatever you're doing. -
Fashion tech-cessory
Even the iPod shuffle clip gets the rock star treatment. Now forged in stainless steel, the clip attaches securely to your shirt, jacket, workout gear, even your backpack. And the sleek, durable, anodized aluminum case - makes iPod shuffle a wardrobe essential. -
Multiple playlists
You've probably made multiple playlists in iTunes. With the iPod shuffle, you can sync your playlists and always find the perfect mix for your activity or mood. VoiceOver tells you the name of each playlist, so it's easy to switch between them and find the one you want without looking. -
Multi-music-lingual
Your music library has songs from all over the world. That's why VoiceOver speaks 14 different languages. So it can tell you song titles and artists in the correct languages. -
Shuffle, straight, stop
- Apple iPod shuffle - digital player
- Product Type
- Digital player flash based
- Enclosure Colour
- Gold
- 3.16 cm x 0.87 cm x 2.9 cm
- 12.5 g
- Playback Digital Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, Audible AAX, Audible AAX+, protected AAC
- Sound Output Mode
- Stereo
- iPod Generation
- 4G
- Audio Specifications
- Digital Player - response bandwidth: 20 - 20000 Hz
- Internal Memory
- 2 GB
- Headphones
- Headphones - binaural - ear-bud - stereo
- Battery
- Rechargeable - Lithium Ion
- 1-year warranty
- Product Type
- Digital player
- Digital Player Type
- Flash based
- Enclosure Colour
- Gold
- Enclosure Material
- Aluminium
- Audio Formats
- iPod Generation
- 4G
Audio System
- Internal Memory
- 2 GB
- File System Supported
- 2 GB
- Sound Output Mode
- Stereo
- Functions
- Digital player
- Digital Player - response time: 20 - 20000 Hz
- USB 2.0 compatibility, VoiceOver, built-in clip
Digital Player (Recorder)
- Supported Bit Rate
- 8 - 320Kbps
- Variable bit-rate compatible
Headphones
- Headphones Type
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Frequency Response
- 20 - 20000 Hz
- Impedance
- 32 Ohm
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- USB adapter cable, Apple EarPods
- Integrated Battery
- Run Time (Up To)
- 15 hour(s)
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.7.5 or later
- Software Requirements
- iTunes 12.2 or later
- Additional Requirements
- USB port (compatible with 2.0 specification)
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 3.16 cm
- 0.87 cm
- 2.9 cm
- 12.5 g
