Apple iPhone XS Max Silicone Case – Black
Quicklinx: DWCQWS00 Mfr#: MRWE2ZM/A
Designed by Apple to complement iPhone, the form of the silicone case fits snugly over the volume buttons, side button, and curves of your device without adding bulk. A soft microfiber lining on the inside helps protect your iPhone. On the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. And you can keep it on all the time, even when you’re charging wirelessly.
Apple - back cover for mobile phone
Back cover for mobile phone
Material
Silicone
iPhone XS Max
Material
Silicone
Lining Material
Microfibre
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Apple iPhone XS Max
