These Apple-designed cases fit snugly over the curves of your iPhone without adding bulk. They're made from specially tanned and finished European leather, so the outside feels soft to the touch and develops a natural patina over time. The machined aluminum buttons match the finish of your leather case, while a microfiber lining inside helps protect your iPhone. And you can keep it on all the time, even when you're charging wirelessly.
A case worthy of iPhone 5s
iPhone 5s has a stunning exterior. So any case that dares to conceal it should be equally appealing. The Apple-designed leather cases more than meet the requirement. Made from premium leather, they look and feel luxurious. And because they're precision crafted for iPhone 5s, your phone still feels incredibly slim even with the case on. -
Precision made, beautifully crafted
The leather is deliberately shaped to cover the volume buttons, the on/off switch and the chamfered edge of iPhone 5s. Inside, a soft microfiber lining protects the exterior of your iPhone. Outside, you see color that's more than surface deep thanks to a dye that's infused into the leather.
- Apple (PRODUCT) RED - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Silicone
- Red
- Material
- Silicone
- Lining Material
- Microfibre
- Red
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
