Apple iPhone 8 Plus / 7 Plus Silicone Case - (PRODUCT)RED
Quicklinx: D436WS00 Mfr#: MQH12ZM/A
Colours:
Designed by Apple to complement your iPhone, the form of the silicone case fits snugly over the volume buttons, side button, and curves of your device without adding bulk. A soft microfiber lining on the inside helps protect your iPhone. On the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. And you can keep it on all the time, even when you're charging iPhone wirelessly.
  • A case worthy of iPhone 5s
    iPhone 5s has a stunning exterior. So any case that dares to conceal it should be equally appealing. The Apple-designed leather cases more than meet the requirement. Made from premium leather, they look and feel luxurious. And because they're precision crafted for iPhone 5s, your phone still feels incredibly slim even with the case on.
  • Precision made, beautifully crafted
    The leather is deliberately shaped to cover the volume buttons, the on/off switch and the chamfered edge of iPhone 5s. Inside, a soft microfiber lining protects the exterior of your iPhone. Outside, you see color that's more than surface deep thanks to a dye that's infused into the leather.
Apple (PRODUCT) RED - back cover for mobile phone
Back cover for mobile phone
Material
Silicone
Red
Apple iPhone 7 Plus
Material
Silicone
Lining Material
Microfibre
Red
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Apple iPhone 7 Plus
