Apple iPhone 8 / 7 Leather Case - Black
Quicklinx: D44XWS00 Mfr#: MQH92ZM/A
Colours:
These Apple-designed cases fit snugly over the curves of your iPhone without adding bulk. They're made from specially tanned and finished European leather, so the outside feels soft to the touch and develops a natural patina over time. The machined aluminum buttons match the finish of your leather case, while a microfiber lining inside helps protect your iPhone. And you can keep it on all the time, even when you're charging iPhone wirelessly.
Apple - back cover for mobile phone
Back cover for mobile phone
Material
Leather
Material
Leather
Lining Material
Microfibre
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
