Apple iPhone 7 Smart Battery Case - Black
Quicklinx: CCGHWS00 Mfr#: MN002ZM/A
12 in stock
£78.55 ex VAT
£94.26 inc VAT
Engineered exclusively for iPhone 7, the Smart Battery Case gives you even longer battery life while offering great protection. Inside, a soft microfiber lining helps protect your iPhone. And on the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. A soft elastomer hinge design makes it easy to put the case on and take it off.
With the Smart Battery Case on, the intelligent battery status is displayed on the iPhone Lock screen and in Notification Center, so you know exactly how much charge you have left.
Apple Smart - battery case - back cover for mobile phone
Battery case back cover for mobile phone
Material
Silicone, elastomer
iPhone 7
Material
Silicone, elastomer
Lining Material
Microfibre
Carrying Case
Battery case
Recommended Use
For mobile phone
Cover Type
Back cover
Cover Features
Soft-touch
Apple iPhone 7
Brand: Apple
Price Range Ex VAT: 50 - 100
