These Apple-designed cases fit snugly over the curves of your iPhone without adding bulk. They're made from specially tanned and finished European leather, so the outside feels soft to the touch and develops a natural patina over time. On the inside, a microfiber lining helps protect your iPhone. And the machined aluminum buttons match the finish of your iPhone case.
- Apple - protective case - back cover for mobile phone
- Product Type
- Protective case back cover for mobile phone
- Material
- Leather
- Saddle brown
- Designed For
- Apple iPhone 7 Plus
- Material
- Leather
- Lining Material
- Microfibre
- Saddle brown
Carrying Case
- Protective case
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Designed For
