This meticulously designed case is made from specially tanned and finished leather for a luxurious feel. The case fits snugly and your smartphone still feels incredibly slim, even with the case on. The soft microfiber lining on the inside helps to protect your device. And on the outside, you see color that's more than surface deep, thanks to the dye that's infused into the leather.
- Apple - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Leather
- Brown
- Material
- Leather
- Lining Material
- Microfibre
- Brown
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
