Apple iPhone 6 Plus Leather Case - Soft Pink
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 9S2TWS00 Mfr#: MGQW2ZM/A
This Apple-designed cases is made from premium leather for a luxurious feel. Because it is precision crafted for iPhone 6 Plus, the case fits snugly and your phone still feels incredibly slim even with the case on. The soft microfiber lining on the inside helps protect your iPhone. And on the outside, you see color that's more than surface deep, thanks to a dye that's infused into the leather.
Apple - back cover for mobile phone
Back cover for mobile phone
Material
Leather
Soft pink
Material
Leather
Soft pink
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Microfibre lined
