Apple iPhone 12 Pro Max 512GB Gold
Quicklinx: G0BRWS00 Mfr#: MGDK3B/A
Operating system: iOS
Screen Size: 6.7in
Rear Camera: 12 Megapixel
Mobile Connectivity: 5G
Network: Not specified
Colours:
£1,165.84 ex VAT
£1,399.00 inc VAT
5G goes Pro. A14 Bionic rockets past every other smartphone chip. The Pro camera system takes low-light photography to the next level — with an even bigger jump on iPhone 12 Pro Max. And Ceramic Shield delivers four times better drop performance. Let’s see what this thing can do.
  • Superfast wireless: hello 5G
    5G transforms iPhone with accelerated wireless speeds and better performance on congested networks. Now you can download huge files on the go or stream high-quality HDR movies. Without. All. The. Lag. iPhone also has the most 5G bands of any smartphone so you get 5G in more places. And all that speed opens up amazing possibilities for the future of apps.
  • A14 Bionic: generations ahead of any other smartphone chip
    A14 Bionic is the first 5-nanometer chip in the industry, with advanced components literally atoms wide. Forty percent more transistors rev up speeds while increasing efficiency for great battery life. And a new ISP powers Dolby Vision recording - something no pro movie camera, let alone any other phone, can do.
  • LiDAR technology: scans the surface of Mars and now your living room
    NASA is using LiDAR technology for its next Mars landing. iPhone 12 Pro Max uses a LiDAR Scanner to measure how long it takes light to reflect back from objects. So it can create a depth map of whatever space you're in. Because it's ultra-fast and accurate, AR apps can now transform a room into a realistic rainforest or show you how a new sneaker will fit.
  • Pro camera system: a new day for Night mode
    Night mode comes to both the Wide and Ultra Wide cameras, and it's better than ever at capturing incredible low-light shots. LiDAR makes Night mode portraits possible. And the Wide camera lets in 27 percent more light, for greater detail and sharper focus day or night.
  • Dolby Vision recording: 60 times more colors, infinitely more spectacular
    iPhone 12 Pro Max jumps from 8- to 10-bit HDR recording, capturing 700 million colors for much more lifelike video. Then it goes one better, recording in Dolby Vision - the format used by film studios. You can even edit Dolby Vision video and use AirPlay to see every last bit of the difference on the big screen.
  • TrueDepth camera: it's never too late to take another Night mode selfie
    Night mode comes to the front camera, bringing all that low-light detail and natural color to your favorite subject. Deep Fusion, Smart HDR 3, and Dolby Vision recording are now on the TrueDepth camera, too. So you'll look your best in any light.
  • Super Retina XDR display: an infinity pool of pixels
    How do you make Apple's brightest display even better? Make it bigger. A new design with flat edges and the flexible custom OLED allowed Apple to push the screen's amazing color, brightness, and contrast right to the very edge.
  • Privacy is built in
    iPhone is designed to protect your information. Face ID data doesn't leave your iPhone and is never backed up to iCloud or anywhere else. iOS shows you an app's privacy practices before you download it. When you use Apple Pay, your card number isn't shared with merchants. And the list goes on.
Apple iPhone 12 Pro Max - gold - 5G - 512 GB - CDMA / GSM - smartphone
Smartphone 5G
Manufacturer Model Number
A2411
Display
OLED display - 2778 x 1284 pixels - 6.7" - 458 ppi - Super Retina XDR Display - HDR - fingerprint-resistant oleophobic coating, Ceramic Shield
Apple A14 Bionic (6-core)
512 GB
Operating System
iOS 14
Rear Camera
12 Megapixel - wide-angle lens - 5x optical zoom - 26 mm - f/1.6 - focus: automatic
Second Rear Camera
12 Megapixel - ultra wide-angle lens 13 mm - f/2.4
Third Rear Camera
12 Megapixel - telephoto lens - f/2.2
Front Camera
12 Megapixel ƒ/2.2
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Bluetooth, Wi-Fi 6, UWB
Security Devices
Face recognition
Connectors
Lightning
Wireless Charging Standards
Qi
Protection
Dustproof, splashproof, waterproof
Gold
78.1 mm x 7.4 mm x 160.8 mm
226 g
SAR
0.99 W/kg (body), 0.99 W/kg (head), 3.85 W/kg (limb)
1-year warranty
Smartphone
A2411
Touch
Protection
78.1 mm
7.4 mm
160.8 mm
226 g
Body Colour
Gold
Body Material
Surgical-grade stainless steel, textured matt glass
SAR Value
Cellular
CDMA2000 1X / GSM / WCDMA (UMTS)
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
iOS 14
Intelligent Assistant
Siri
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Apple Pay
Input Device
Multi-touch, capacitive
Communications
Data Transmission
EDGE, EV-DO, HSPA+, DC-HSDPA, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, Gigabit LTE, LAA, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X
3G UMTS Band
Band 1, Band 5, Band 8, Band 10, Band 25
3G UMTS Frequency
2100, 850, 900, 1700 EAWS, 1900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 30, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 2300 WCS, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n79, n40, n25, n12
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300, FDD 1900, n12
Wireless Interface
NFC, Bluetooth 5.0, IEEE 802.11ax, Ultra-Wideband (UWB)
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, 3-axis gyro sensor, digital compass, barometer, LiDAR scanner
Security Devices
Face recognition
Security Technology
Face ID
Additional Features
AirDrop function, Audio zoom function, MIMO technology, Wi-Fi Calling, iBeacon microlocation, QuickType keyboard, Night Shift, Apple TV support (2nd or later), Raise to wake, Next-generation Neural Engine, Express Transit cards with power reserve, 4K HDR AirPlay Mirroring, FaceTime HD (1080p), RTT/TTY compatible
Media Player
Supported Digital Audio Standards
Audible, MP3, FLAC, Apple Lossless, AC-3, AAC-LC, LPCM, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, HE-AAC v2
Supported Digital Video Standards
M-JPEG, H.264, HEVC, MPEG-4 Part 2, HEIF
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound
Apple A14 Bionic
Processor Core Qty
6-core
Internal Memory Capacity
512 GB
Front Camera
Sensor Resolution
12 Megapixel
Lens Aperture
ƒ/2.2
HDR Mode
Smart HDR 3
Special Effects
Natural, Studio, Contour, Stage, Stage Mono, High-Key Mono
Face Detection
Face recognition
Camera Modes
Burst mode, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos, Time Lapse (Night mode), Smart HDR 3 with Scene Detection
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps
Light Source
Retina Flash
Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, wide colour capture for photos and Live Photos, Extended dynamic range for video at 30 fps, QuickTake video, Time-lapse video with stabilisation, Lens correction, Deep Fusion, HDR video recording with Dolby Vision up to 30 fps
Rear Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Sensor-shift OIS (Optical Image Stabilisation)
Lens Type
Wide-angle lens
Lens Aperture
F/1.6
Lens Construction
7-element
Min Focal Length
26 mm
Pixel Size
1.7 µm
Focus Adjustment
Automatic
Optical Zoom
5
Digital Zoom
12
Special Effects
Camera Modes
Burst mode, Panorama, night mode, low-light shots, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos, Time Lapse (Night mode), Apple ProRAW
Face Detection
Face recognition
HDR Mode
Smart HDR 3
Light Source
True Tone LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
Sapphire crystal lens cover, Cinematic video stabilisation, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, 8MP still photos recording 4K video, Time-lapse video with stabilisation, Slow Sync, wide colour capture for photos and Live Photos, Advanced red-eye correction, HEIF image capture, Audio zoom, 100% Focus Pixels, QuickTake video, Extended dynamic range for video at 60 fps, Deep Fusion, Dolby Vision HDR video recording up to 60 fps, Smart HDR 3 with Scene Detection, Sensor-shift optical image stabilisation for video, Digital zoom up to 7x for video
Second Rear Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.4
Min Focal Length
13 mm
Field of View (FoV)
120 degree(s)
5-piece lens, Lens correction
Third Rear Camera
Sensor Resolution
12 Megapixel
Lens Type
Telephoto lens
Lens Aperture
F/2.2
OIS (Optical Image Stabilization), 6-piece lens, Focus Pixels, 65 mm focal length
Display
OLED display
Diagonal Size
6.7"
Display Resolution
2778 x 1284 pixels
Pixel Density
458 ppi
Max Brightness
800 cd/m²
HDR
HDR Technology
HDR10
Enhancement Technology
Dolby Vision
Contrast Ratio
2000000:1
Protection
Fingerprint-resistant oleophobic coating, Ceramic Shield
Display Languages
Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English, Australian English, French Canadian, Spanish (Latin American), Chinese (Traditional, Hong Kong), Spanish (Mexican)
True Tone display, Wide colour display (P3), Haptic touch, Hybrid Log-Gamma (HLG), 1200 nits max brightness (HDR)
Connector Type
Lightning
Lithium Ion
Fast Charging Technology
Apple fast charging technology, Apple MagSafe wireless charging
Wireless Charging
Qi
Run Time Details
Playback (video): up to 20 hrs , Playback (streamed video): up to 12 hrs , Playback (audio): up to 80 hrs
IEC 60529 IP68, HAC (Hearing Aid Compatible)
Lightning to USB-C cable
Limited warranty - 1 year , Technical support - consulting - 90 days
Max Depth of Water Resistance
6 m
35 °C
5 - 95% (non-condensing)
G0BR Apple Lightning to VGA Adapter In Stock £36.40
G0BR Apple Lightning Digital AV Adapter In Stock £47.60
G0BR Apple Lightning to USB Camera Adapter In Stock £22.39
G0BR Apple Lightning to USB Cable (0.5m) In Stock £18.46
G0BR Apple Lightning to USB Cable (2 m) In Stock £28.17
G0BR Apple Lightning to SD Card Camera Reader In Stock £21.42
G0BR Apple USB-C to Lightning Cable 2m In Stock £31.57
G0BR Apple EarPods with Lightning Connector In Stock £14.12
G0BR Apple Lightning to 3.5 mm Headphone Jack Adapter In Stock £7.10
G0BR Apple Lightning to USB 3 Camera Adapter In Stock £28.96
G0BR Apple Magic Keyboard with Numeric Keypad - UK Layout In Stock £102.15
G0BR Apple Magic Keyboard with Numeric Keypad - Keyboard - Blueto In Stock £104.19
G0BR Apple AirPods Pro With Wireless Case In Stock £158.33
G0BR Apple Lightning to USB Cable (1m) In Stock £17.14
G0BR Beats Solo3 Wireless Headphones - Black In Stock £176.42
G0BR Apple 12W USB Power Adapter In Stock £15.30
G0BR Beats Flex – All-Day Wireless Earphones – Black In Stock £41.66
G0BR Apple AirPods with Charging Case In Stock £104.16
G0BR Apple MagSafe Charger In Stock £31.94
G0BR Apple 5W USB Power Adapter Folding Pins In Stock £22.89
G0BR Apple IPHONE 12 Pro Max LE Case Black In Stock £46.58
G0BR Apple AirPods Max - Space Grey In Stock £457.50
G0BR Apple AirPods Max - Silver In Stock £457.50
G0BR Apple AirPods Max - Green In Stock £457.50
G0BR Apple AirPods Max - Pink In Stock £457.50
G0BR Apple USB-C - Power adapter - 30 Watt - United Kingdom In Stock £41.23
G0BR Apple AirTag In Stock £24.17
G0BR Apple AirTag 4-Pack In Stock £82.50
G0BR Apple Leather Wallet for iPhone 12 In Stock £46.58
Screen Size: 6.7in
Model: 12 Pro Max
Brand: Apple
Price Range Ex VAT: £1000 - £1500
