Apple iPhone 11 Pro Max 256GB Midnight Green
Quicklinx: FDK7WS00 Mfr#: MWHM2B/A
Colours:
And then there was Pro.
A transformative triple-camera system that adds tons of capability without complexity. An unprecedent­ed leap in battery life. And a mind-blowing chip that elevates machine learning and pushes the boundaries of what a smartphone can do. Welcome to the first iPhone powerful enough to be called Pro.
  • Pro camera system
    Capture up to four times more scene. Get beautiful images in drastically lower light. Shoot the high-quality video in a smartphone - then edit with the same tools you love for photos. You've never shot with anything like it.
  • 4K video
    iPhone 11 Pro lets you capture videos that are beautifully true to life, with greater detail and smoother motion. Epic processing power means it can shoot 4K video with extended dynamic range and cinematic video stabilization - all at 60 fps. You get more creative control, too, with four times more scene and powerful editing tools to play with.
  • Ultra Wide
    When you just can't squeeze everything into the frame, zoom out. Because the Ultra Wide camera captures four times more scene than ever. It's like stepping back - way back - without taking a step. Bring on those mountain ranges, soaring cathedrals, and iconic skylines.
  • Night mode
    From dimly lit restaurants to moonlit beaches, the Night mode uses intelligent software and A13 Bionic to deliver low-light shots never before possible on iPhone. And it all happens automatically. You can also experiment with manual controls to dial in even more detail and less noise.
  • Portrait mode
    With three cameras working together, you can fit more in your portraits than ever. iOS 13 adds the High-Key Light Mono effect for studio-style monochromes. And Portrait Lighting lets you control the intensity of light to flatter your subject - just like you would in a studio. How beautiful is that?
  • Smart HDR
    Next-generation Smart HDR uses advanced algorithms to finesse highlight and shadow detail in your image. And now it leverages machine learning to recognize faces in your shot and intelligently relight them. That means iPhone 11 Pro Max can automatically fine-tune detail in both the subject and the background. Even some DSLR cameras can't do that.
  • Be ready when your photo op turns into a video op
    Say you're taking photos and you see something you've got to catch on video. With QuickTake, there's no need to switch modes. Just leave your finger on the shutter to start recording. Want to keep the recording going? Swipe right. To take burst photos, swipe left.
  • Super Retina XDR
    The Super Retina XDR display boasts not one but two peaks of brightness and understands when to use them. It hits up to 800 nits when you're out in the sun - great for shooting and making selects on the go - and up to 1200 nits when you're viewing extreme dynamic range content. It's like having a Pro Display XDR on your iPhone.
  • Privacy is built in
    Everything about iPhone is engineered to protect your privacy. Face ID data doesn't leave your iPhone and is never backed up to iCloud or anywhere else. Maps tells you where you're going without telling anyone where you are. Every iMessage you send is encrypted end-to-end. And the list goes on.
  • Excellent trade-in value
    iPhone 11 Pro Max is designed to last, so it holds its value longer. Should you ever decide to part with it, you can use that value toward your next iPhone.
Apple iPhone 11 Pro Max - midnight green - 4G smartphone - 256 GB - GSM
4G smartphone
Manufacturer Model Number
A2218
Display
OLED display - 2688 x 1242 pixels - 6.5" - 458 ppi - Super Retina XDR Display - HDR - fingerprint-resistant oleophobic coating
Apple A13 Bionic (6-core) - 64-bit
256 GB
Operating System
iOS 13
Main Camera
12 Megapixel - wide-angle lens - 2x optical zoom - 26 mm - f/1.8 - focus: automatic
Second Camera
12 Megapixel - ultra wide-angle lens 26 mm - f/2.4
Third Camera
12 Megapixel - telephoto lens 52 mm - f/2.0 - capture depth information
Front Camera
12 Megapixel f/2.2
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Bluetooth, Wi-Fi 6
Security Devices
Face recognition
Messaging Services
SMS, MMS
Connectors
Lightning
Wireless Charging Standards
Qi
Protection
Dustproof, splashproof, waterproof, spill-resistant
Midnight green
77.8 mm x 8.1 mm x 158 mm
226 g
0.95 W/kg (head) , 0.99 W/kg (body)
1-year warranty
Smartphone
A2218
Touch
Protection
77.8 mm
8.1 mm
158 mm
226 g
Body Colour
Midnight green
Body Material
Surgical-grade stainless steel, textured matt glass
SAR Value
0.99 W/kg (body), 0.95 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
iOS 13
Intelligent Assistant
Siri
Navigation
GPS, GLONASS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Apple Pay
Input Device
Touch screen, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, DC-HSDPA, LTE Advanced, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, Gigabit LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 11, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 21, Band 25, Band 26, Band 28, Band 29, Band 30, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 1500, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1500 upper, FDD 1900+, FDD 850+, FDD 700 APT, FDD 700d, FDD 2300 WCS, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, Bluetooth 5.0, IEEE 802.11ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, 3-axis gyro sensor, digital compass, barometer
Security Devices
Face recognition
Security Technology
Face ID
Additional Features
TTY compatible, FaceTime, AirDrop function, Audio zoom function, MIMO technology, Wi-Fi Calling, iBeacon microlocation, QuickType keyboard, Night Shift, Apple TV support (2nd or later), AirPlay Mirroring, Third-generation Neural Engine, FaceTime audio, U1 chip
Media Player
Supported Digital Audio Standards
Audible, MP3, FLAC, Apple Lossless, AC-3, AAC-LC, LPCM, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, HE-AAC v2
Supported Digital Video Standards
M-JPEG, H.264, HEVC, MPEG-4 Part 2, HEIF
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound
Apple A13 Bionic
Processor Core Qty
6-core
64-bit Architecture
Internal Memory Capacity
256 GB
Front Camera
Sensor Resolution
12 Megapixel
Lens Aperture
F/2.2
HDR Mode
Smart HDR
Special Effects
Natural, High Key, Studio, Contour, Stage, Stage Mono
Face Detection
Face recognition
Camera Modes
Burst mode, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps
Light Source
Retina Flash
Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, Extended dynamic range for video at 30 fps
Main Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Dual OIS (Optical Image Stabilisation)
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Lens Construction
6-element
Min Focal Length
26 mm
Focus Adjustment
Automatic
Optical Zoom
2x
Digital Zoom
10x
Special Effects
Camera Modes
Burst mode, Panorama, night mode, low-light shots, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos
Face Detection
Face detection
HDR Mode
Smart HDR
Light Source
True Tone LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
Cinematic video stabilisation, Zero Shutter Lag, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, 8MP still photos recording 4K video, Time-lapse video with stabilisation, Slow Sync, Advanced red-eye correction, Optical image stabilization for video, Extended dynamic range for video, HEIF image capture, Audio zoom, 100% Focus Pixels
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.4
Min Focal Length
26 mm
Lens Element Qty
5-element
Field of View (FoV)
120 degree(s)
5-piece lens
Third Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser (OIS)
Lens Type
Telephoto lens
Lens Aperture
F/2.0
Min Focal Length
52 mm
Functions
Capture depth information
Optical image stabilisation for video, 6-piece lens
Display
OLED display
Diagonal Size
6.5"
Display Resolution
2688 x 1242 pixels
Pixel Density
458 ppi
Max Brightness
1200 cd/m²
HDR
HDR Technology
HDR10
Enhancement Technology
Dolby Vision
Contrast Ratio
2000000:1
Protection
Fingerprint-resistant oleophobic coating
Display Languages
Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English, Australian English, French Canadian, Spanish (Latin American)
True Tone display, Wide colour display (P3), Dark mode
Connector Type
Lightning
Lithium Ion
Fast Charging Technology
Apple fast charging technology
Wireless Charging
Qi
Run Time Details
Playback (video): up to 20 hrs , Playback (wireless video): up to 12 hrs , Playback (audio): up to 80 hrs
IEC 60529 IP68, HAC (Hearing Aid Compatible)
Apple EarPods with Lightning Connector, 18W USB-C power adapter, Lightning to USB-C cable
Limited warranty - 1 year , Technical support - consulting - 90 days
Max Depth of Water Resistance
4 m
35 °C
5 - 95% (non-condensing)
