Learn, play, surf, create. iPad gives you the incredible display, performance and apps to do what you love to do. Anywhere. Easily. Magically.
Brilliant display. Brilliant size.
Whether you're enjoying photos, shopping or building a presentation, the vivid 9.7-inch Retina display has the detail and size to really bring them to life.
Watch, play and create at full speed.
The 64-bit A9 chip delivers performance that makes every app feel fast and fluid. Explore rich learning apps, play graphics-intensive games, or even use two apps at once. All while enjoying up to 10 hours of battery life.
Over a million apps designed for iPad.
Every iPad app has been designed specifically for the power and scale of iPad. And with so many great iPad apps in the App Store, there's sure to be an app for whatever you love to do.
Personal. Powerful. Playful.
iOS 10 is designed to be advanced, intuitive and secure. It's so capable, you can work and play using two apps at once, ask Siri to send a message for you, and automatically back up your files with iCloud so you can access them anywhere. And it includes built-in apps that help you get more out of iPad.
Unlock, sign in and buy with a touch.
Your fingerprint is the perfect password because it's unique and always with you. Touch ID lets you unlock your iPad instantly and secure private data in apps. You can also use it to make purchases with Apple Pay in apps and websites.
Photos. Videos. FaceTime. You're covered.
Taking photos and videos with iPad is a cinch. Use the 8-megapixel camera to shoot detailed images or 1080p HD video, then edit them straight on iPad with Photos, iMovie or your favourite app from the App Store. Or use the front-facing FaceTime HD camera for video calls and gorgeous selfies.
All your devices. One seamless experience.
iPad works seamlessly with your other devices. Start an email on your iPhone and finish it on iPad. Or copy images, video and text from your iPad, then paste to your nearby Mac. You can even use AirDrop to share files wirelessly -- and instantly -- between devices.
Built to go places.
At less than half a kilo and only 7.5mm thin, iPad is designed to go wherever you go. And it's as durable as it is portable, with an aluminium unibody construction that delivers a reassuringly solid feel.
- Apple 9.7-inch iPad Wi-Fi - 5th generation - tablet - 32 GB - 9.7"
- Product Type
- Tablet
- Display
- 9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
- Processor
- Apple A9 - 64-bit
- Storage
- 32 GB
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Rear Camera
- 8 Megapixel focus: automatic
- Front Camera
- 1.2 Megapixel
- Security Devices
- Fingerprint reader
- Battery Run Time
- Up to 10 hours
- 16.95 cm x 0.75 cm x 24 cm
- 469 g
- Gold
- Localisation
- English / United Kingdom
- Specific Absorption Rate (SAR)
- 0.41 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iOS 12
Display
- Resolution
- Touchscreen
- Multi-Touch
- Anti-fingerprint, Retina display
- Processor
- Apple A9
- 64-bit Computing
- Storage
- 32 GB
Communications
Rear Camera
- Sensor Resolution
- 8 Megapixel
- Focus Adjustment
- Automatic
- Lens Aperture
- F/2.4
- HDR Mode
- Auto HDR mode
- Face Detection
- Face detection
- Cinematic video stabilisation, Live Photo, Hybrid IR filter, Exposure control, geotagging
Front Camera
- Sensor Resolution
- 1.2 Megapixel
- Lens Aperture
- F/2.2
- FaceTime HD camera
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
- Audio
- Stereo speakers
Input Device
- Security Devices
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, News, Find My iPhone, Siri, Reminders, Music, Find My Friends, Control Center, iTunes Store, Podcasts, iCloud Drive, Notification Center, Spotlight Search, Apple Pay, Apple TV App, Home
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.9.5 or later
Expansion and Connectivity
- 1 x headphones mini jack (3.5mm) , 1 x Lightning
- Technology
- Lithium polymer
- Capacity
- 32.4 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
- Gold
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
- Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Apple M9 motion coprocessor, Family Sharing, Night Shift
- Included Accessories
- Power adapter
- Cables Included
- Lightning to USB cable
- 0.41 W/kg (body)
- Localisation
- 16.95 cm
- 0.75 cm
- 24 cm
- 469 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
- Max Altitude Operating
- 3 km
