Apple iPad Wi-Fi 128GB - Gold
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: CSPSWS00 Mfr#: MPGW2B/A
Colours:
Learn, play, surf, create. iPad gives you the incredible display, performance and apps to do what you love to do. Anywhere. Easily. Magically.
Brilliant display. Brilliant size.
Whether you're enjoying photos, shopping or building a presentation, the vivid 9.7-inch Retina display has the detail and size to really bring them to life.
Watch, play and create at full speed.
The 64-bit A9 chip delivers performance that makes every app feel fast and fluid. Explore rich learning apps, play graphics-intensive games, or even use two apps at once. All while enjoying up to 10 hours of battery life.
Over a million apps designed for iPad.
Every iPad app has been designed specifically for the power and scale of iPad. And with so many great iPad apps in the App Store, there's sure to be an app for whatever you love to do.
Personal. Powerful. Playful.
iOS 10 is designed to be advanced, intuitive and secure. It's so capable, you can work and play using two apps at once, ask Siri to send a message for you, and automatically back up your files with iCloud so you can access them anywhere. And it includes built-in apps that help you get more out of iPad.
Unlock, sign in and buy with a touch.
Your fingerprint is the perfect password because it's unique and always with you. Touch ID lets you unlock your iPad instantly and secure private data in apps. You can also use it to make purchases with Apple Pay in apps and websites.
Photos. Videos. FaceTime. You're covered.
Taking photos and videos with iPad is a cinch. Use the 8-megapixel camera to shoot detailed images or 1080p HD video, then edit them straight on iPad with Photos, iMovie or your favourite app from the App Store. Or use the front-facing FaceTime HD camera for video calls and gorgeous selfies.
All your devices. One seamless experience.
iPad works seamlessly with your other devices. Start an email on your iPhone and finish it on iPad. Or copy images, video and text from your iPad, then paste to your nearby Mac. You can even use AirDrop to share files wirelessly -- and instantly -- between devices.
Built to go places.
At less than half a kilo and only 7.5mm thin, iPad is designed to go wherever you go. And it's as durable as it is portable, with an aluminium unibody construction that delivers a reassuringly solid feel.
  • Stunning Retina display
    Whether you're enjoying photos, shopping, or building a presentation, the vivid Retina display has the detail and size to really bring them to life.
  • Fast, fluid performance
    The powerful chip delivers performance that makes every app feel fast and fluid. Explore rich learning apps, play graphics-intensive games, or even use two apps at once.
  • Front and back cameras
    Taking photos and videos with iPad is a snap. Use the 8-megapixel camera to shoot detailed images or video. Or use the front-facing camera for video calls and gorgeous selfies.
  • Durable and portable
    Light and thin, iPad is designed to go wherever you go. And it's as durable as it is portable, with an aluminum unibody construction that delivers a reassuringly solid feel.
Apple 9.7-inch iPad Wi-Fi - 5th generation - tablet - 128 GB - 9.7"
Tablet
Display
9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
Apple A9 - 64-bit
Storage
128 GB
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 4.2
Rear Camera
8 Megapixel focus: automatic
Front Camera
1.2 Megapixel
Security Devices
Fingerprint reader
Battery Run Time
Up to 10 hours
16.95 cm x 0.75 cm x 24 cm
469 g
Gold
English / United Kingdom
0.41 W/kg (body)
1-year warranty
Tablet
Operating System
Apple iOS 12
Display
Resolution
Touchscreen
Multi-Touch
Anti-fingerprint, Retina display
Apple A9
64-bit Computing
Storage
128 GB
Communications
Rear Camera
Sensor Resolution
8 Megapixel
Focus Adjustment
Automatic
Lens Aperture
F/2.4
HDR Mode
Auto HDR mode
Face Detection
Face detection
Cinematic video stabilisation, Live Photo, Hybrid IR filter, Exposure control, geotagging
Front Camera
Sensor Resolution
1.2 Megapixel
Lens Aperture
F/2.2
FaceTime HD camera
Multimedia
Supported Digital Audio Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
Audio
Stereo speakers
Input Device
Security Devices
Fingerprint reader
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, News, Find My iPhone, Siri, Reminders, Music, Find My Friends, Control Center, iTunes Store, Podcasts, iCloud Drive, Notification Center, Spotlight Search, Apple Pay, Apple TV App, Home
System Requirements for PC Connection
Microsoft Windows 7 or later, Apple MacOS X 10.9.5 or later
Expansion and Connectivity
1 x headphones mini jack (3.5mm) , 1 x Lightning
Lithium polymer
32.4 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
Gold
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Apple M9 motion coprocessor, Family Sharing, Night Shift
Power adapter
Lightning to USB cable
0.41 W/kg (body)
16.95 cm
0.75 cm
24 cm
469 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
Max Altitude Operating
3 km
