Apple iPad Wi-Fi + Cellular 32GB - Space Grey
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: DGBMWS00 Mfr#: MR6Y2B/A
Colours:
Whether you're enjoying photos, shopping, or building a presentation, the vivid 9.7-inch Retina display has the detail and size to really bring them to life. The 64-bit A9 chip delivers performance that makes every app feel fast and fluid. Explore rich learning apps, play graphics-intensive games, or even use two apps at once. All while enjoying up to 10 hours of battery life. Taking photos and videos with iPad is a snap. Use the 8-megapixel camera to shoot detailed images or 1080p HD video and then edit them right on iPad with Photos, iMovie, or your favorite app from the App Store. Or use the front-facing FaceTime HD camera for video calls and gorgeous selfies. At just one pound and 7.5 mm thin, iPad is designed to go wherever you go. And it's as durable as it is portable, with an aluminum unibody construction that delivers a reassuringly solid feel.
iPad is designed to stay connected wherever you go. Fast 802.11ac Wi-Fi delivers up to 866-Mbps throughput. The Wi-Fi + Cellular model supports LTE networks worldwide for convenient connectivity.
  • Stunning Retina display
    Whether you're enjoying photos, shopping, or building a presentation, the vivid Retina display has the detail and size to really bring them to life.
  • Fast, fluid performance
    The powerful chip delivers performance that makes every app feel fast and fluid. Explore rich learning apps, play graphics-intensive games, or even use two apps at once.
  • Front and back cameras
    Taking photos and videos with iPad is a snap. Use the 8-megapixel camera to shoot detailed images or video. Or use the front-facing camera for video calls and gorgeous selfies.
  • Durable and portable
    Light and thin, iPad is designed to go wherever you go. And it's as durable as it is portable, with an aluminum unibody construction that delivers a reassuringly solid feel.
Apple 9.7-inch iPad Wi-Fi + Cellular - 6th generation - tablet - 32 GB - 9.7" - 3G, 4G
Tablet
Display
9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
Apple A10 Fusion (Quad-Core) - 64-bit
Storage
32 GB
Cellular Technology
3G, 4G
Cellular Protocols
GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 4.2
Camera
8 Megapixel (rear), 1.2 Megapixel (front)
HD Video Recording
1080p
Navigation System
A-GPS/GLONASS
Security Devices
Fingerprint reader
Battery Run Time
Up to 10 hours
16.95 cm x 0.75 cm x 24 cm
478 g
Space grey
English / United Kingdom
1-year warranty
Tablet
Operating System
Apple iOS 12
Display
Resolution
Touchscreen
Multi-Touch
Anti-fingerprint, Retina display, Apple Pencil support
Apple A10 Fusion
Number of Cores
Quad-Core
64-bit Computing
Storage
32 GB
Communications
Cellular Technology
3G, 4G
Cellular Protocols
Band
GSM 850/900/1800/1900 / UMTS 850/900/1700/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700 / 700 APT/700b/700c/700 de/800 DD/800/850/900/1800/1900/TD 1900/2100/TD 2300/TD 2500/2600/TD 2600/AWS
Camera
Resolution (MP)
Lens Aperture
F/2.4 (rear) / f/2.2 (front)
HD Video Recording
1080p
Video stabilizer, tap to focus, photo and video geotagging, autofocus, FaceTime HD camera, Burst mode, Slow motion video, backside illumination sensor, HDR (High Dynamic Range), Time-lapse mode, Panorama, 5-element lens, Hybrid IR filter, Timer mode, Exposure control, Auto image stabilisation, Live Photo, Retina Flash, body and face detection
Navigation System
Receiver
A-GPS/GLONASS
Multimedia
Supported Digital Audio Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
Audio
Stereo speakers
Input Device
Security Devices
Fingerprint reader
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure
System Requirements for PC Connection
Microsoft Windows 7 or later, Apple MacOS X 10.10.5 or later
Expansion and Connectivity
1 x headphones mini jack (3.5mm) , 1 x Lightning
Lithium polymer
32.4 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
Space grey
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
Charging via USB, VoiceOver screen reader, AirPlay, Dictation, AssistiveTouch, MIMO technology, iBeacon microlocation, Apple M10 motion coprocessor
Power adapter, Apple SIM
Lightning to USB cable
16.95 cm
0.75 cm
24 cm
478 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
Max Altitude Operating
3 km
