Apple iPad Smart Cover - Charcoal Gray
Quicklinx: CSWMWS00 Mfr#: MQ4L2ZM/A
Device Type: iPad
Type: Bags & Cases
Device Screen Size: 9.7"
Colour: Charcoal grey
£33.80 ex VAT
£40.56 inc VAT
Apple Smart Polyurethane flip cover for 9.7" iPad; iPad Air 2 - Charcoal Grey.
  • Thin, minimal design
    The lightweight, durable Smart Cover protects your iPad screen without covering up its aluminum back. So your iPad still looks and feels like an iPad - just with a little extra protection.
  • Polyurethane design
    The Smart Cover is made of polyurethane. It also features a soft, color-matched microfiber lining that helps keep your display clean.
  • Magnetic connection
    A hinge magnetically aligns the Smart Cover with iPad for a perfect fit, while magnets inside help it stay put.
  • Keyboard stand
    The Smart Cover does double duty as a keyboard stand. Fold it back to tilt iPad into a comfortable writing position.
  • Wake on open, sleep on close
    Open the Smart Cover, and iPad magically wakes up. Close it, and iPad automatically goes to sleep.
  • FaceTime and movie stand
    The Smart Cover folds in just the right places to become the perfect FaceTime and movie-watching stand.
Apple Smart - flip cover for tablet
Flip cover for tablet
Material
Polyurethane
Charcoal grey
9.7-inch iPad (5th generation, 6th generation); iPad Air 2
Material
Polyurethane
Lining Material
Microfibre
Charcoal grey
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Flip cover
Open Type
Side
Closure Type
Magnetic closure
Cover Features
Stand function
Apple 9.7-inch iPad (5th generation, 6th generation) , Apple iPad Air 2
Apple iPad Smart Cover - Charcoal Gray Bundle deal on Apple iPad Smart Cover - Charcoal Gray
£132.97
Device Type: iPad
Type: Bags & Cases
Brand: Apple
Price Range Ex VAT: 0 - 50
