The lightweight, durable Smart Cover protects your iPad Pro screen without covering up its aluminium back. For total front-and-back coverage, you can pair it with an iPad Pro Silicone Case. A magnetic hinge aligns the Smart Cover with iPad Pro for a perfect fit and helps it stay put. Open the Smart Cover to wake iPad Pro. Close it and iPad Pro goes to sleep.
- Apple Smart - screen cover for tablet
- Product Type
- Screen cover for tablet
- Charcoal grey
- Designed For
- 12.9-inch iPad Pro (1st generation, 2nd generation)
- Charcoal grey
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Cover Type
- Screen cover
- Open Type
- Side
- Cover Features
- Stand function
- Designed For
- Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
