Apple iPad Pro Smart Cover Charcoal Gray
Quicklinx: BRK3WS00 Mfr#: MK0L2ZM/A
The lightweight, durable Smart Cover protects your iPad Pro screen without covering up its aluminium back. For total front-and-back coverage, you can pair it with an iPad Pro Silicone Case. A magnetic hinge aligns the Smart Cover with iPad Pro for a perfect fit and helps it stay put. Open the Smart Cover to wake iPad Pro. Close it and iPad Pro goes to sleep.
Apple Smart - screen cover for tablet
Screen cover for tablet
Charcoal grey
12.9-inch iPad Pro (1st generation, 2nd generation)
Charcoal grey
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Screen cover
Open Type
Side
Cover Features
Stand function
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
