Your basket is empty
Apple iPad Pro Smart Cover Charcoal Gray
Quicklinx: BRK3WS00 Mfr#: MK0L2ZM/A
The lightweight, durable Smart Cover protects your iPad Pro screen without covering up its aluminium back. For total front-and-back coverage, you can pair it with an iPad Pro Silicone Case. A magnetic hinge aligns the Smart Cover with iPad Pro for a perfect fit and helps it stay put. Open the Smart Cover to wake iPad Pro. Close it and iPad Pro goes to sleep.
Apple Smart screen cover for tablet
Screen cover for tablet
Charcoal grey
12.9-inch iPad Pro
Charcoal grey
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Screen cover
Open Type
Side
Cover Features
Stand function
Apple 12.9-inch iPad Pro
