Apple iPad Pro 9.7-inch Wi-Fi 32GB Rose Gold
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: C0YRWS00 Mfr#: MM172B/A
iPad Pro is more than the next generation of iPad - it's an uncompromising vision of personal computing for the modern world. It puts incredible power that leaps past most portable PCs at your fingertips. It makes even complex work as natural as touching or swiping. iPad Pro is more capable, versatile, and portable than anything that's come before. In a word, super.
  • Retina Display: an awesome display of progress
    The key to the iPad experience is the display. It's how you interact using multi-touch, and how you view content in spectacular detail.
  • Four speaker audio: no matter how you turn it, you'll want to turn it up
    With a high-fidelity speaker in each corner, iPad Pro creates a rich, wide, and detailed soundstage. It automatically adjusts the orientation of the high frequencies to the topmost speakers, no matter how you're holding it. So whether you're playing a game or watching a movie, you - and your ears - will be completely immersed.
  • A9X chip: faster than a speeding laptop
    The 64-bit A9X chip gives iPad Pro the power to easily take on tasks once reserved for workstations and PCs. Not to mention tasks you'd never consider doing on a PC. Despite this barrier-breaking performance, the A9X chip's efficient architecture enables up to 10 hours of battery life.
  • Quicker work
    With up to 1.8 times the CPU performance of iPad Air 2, the A9X chip delivers incredible responsiveness. Even complex actions like editing 4K video happen immediately and with unparalleled smoothness.
  • More beautiful play
    iPad Pro offers up to double the graphics performance of iPad Air 2. That means it can render incredibly detailed visuals, fluid animations, and effects so real, you'll lose yourself in your favorite apps and games.
  • A game changer
    Metal optimizes CPU and graphics like nothing else. So developers can design even more highly immersive console-style games and blazing-fast apps.
  • iSight and FaceTime HD cameras: capture every detail in greater detail
    iPad Pro has remarkable cameras on both the front and the back. It's also the first iPad with True Tone flash, so skin tones look great regardless of lighting. Things are sharper on the other side of iPad Pro, too. The front-facing FaceTime HD camera's sensor makes video calls more lifelike.
  • Design: incredible power has never been so easy to handle
    Even though iPad Pro can handle tasks usually reserved for PCs, it's lighter than any PC could hope to be. And thanks to the aluminum unibody, it feels reassuringly solid in the hand.
  • Fast wireless connectivity
    iPad Pro can connect to the fastest Wi-Fi networks so you can surf the web, stream movies and share documents from virtually anywhere.
  • Touch ID: the password is you
    iPad Pro uses Touch ID technology to turn your fingerprint into an unforgettable password. So you can unlock your device with just a touch. You can also make secure purchases in iTunes, iBooks, and the App Store. And with Apple Pay, you can make purchases within your apps easily and securely.
Apple 9.7-inch iPad Pro Wi-Fi - 1st generation - tablet - 32 GB - 9.7"
Tablet
Display
9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
Apple A9X - 64-bit
Storage
32 GB
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 4.2
Rear Camera
12 Megapixel focus: automatic
Front Camera
5 Megapixel
Security Devices
Fingerprint reader
Battery Run Time
Up to 10 hours
16.95 cm x 0.61 cm x 24 cm
437 g
Rose gold
English / United Kingdom
0.72 W/kg (body)
1-year warranty
Tablet
Operating System
Apple iOS 9
Display
Resolution
Touchscreen
Multi-Touch
Anti-glare, anti-fingerprint, Retina display, fully laminated display, True Tone display, Wide colour display
Apple A9X
64-bit Computing
Storage
32 GB
Communications
Rear Camera
Sensor Resolution
12 Megapixel
Focus Adjustment
Automatic
HDR Mode
Auto HDR mode
Face Detection
Face detection
Sapphire crystal lens cover, Cinematic video stabilisation, Focus Pixels, Cinematic video stabilisation, Live Photo, Hybrid IR filter, Improved noise reduction, Exposure control, geotagging
Front Camera
Sensor Resolution
5 Megapixel
FaceTime HD camera
Multimedia
Supported Digital Audio Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, HE-AAC, protected AAC
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 5.0 (up to 1080p)
Audio
Two microphones, four speakers
Input Device
Security Devices
Fingerprint reader
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, News, Find My iPhone, Siri, Reminders, Music, Find My Friends, Control Center, iTunes Store, Podcasts, iCloud Drive, Notification Center, Spotlight Search
System Requirements for PC Connection
Microsoft Windows 7 or later, Apple OS X 10.8.5 Mountain Lion or later
Expansion and Connectivity
1 x headphones , 1 x Lightning , 1 x Smart Connector
Lithium polymer
27.5 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
Rose gold
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Apple M9 motion coprocessor, Family Sharing, Night Shift, CarPlay
Power adapter
Lightning to USB cable
0.72 W/kg (body)
16.95 cm
0.61 cm
24 cm
437 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
