Apple iPad mini 4 Smart Cover - Orange
Quicklinx: BNKRWS00 Mfr#: MKM22ZM/A
The Smart Cover for iPad mini 4 is constructed from a single piece of polyurethane to protect the front of your device. It automatically wakes your iPad when opened and puts it to sleep when closed. You can easily fold the Smart Cover into different positions to create a stand for reading, viewing, typing, or making FaceTime calls. And it's easy to remove, so you can snap it on and off whenever you want.
Apple Smart - screen cover for tablet
Screen cover for tablet
Material
Polyurethane
Orange
iPad mini 4 (4th generation)
Material
Polyurethane
Orange
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Screen cover
Open Type
Side
Cover Features
Stand function
Apple iPad mini 4 (4th generation)
