The Smart Cover for iPad mini 4 is constructed from a single piece of polyurethane to protect the front of your device. It automatically wakes your iPad when opened and puts it to sleep when closed. You can easily fold the Smart Cover into different positions to create a stand for reading, viewing, typing, or making FaceTime calls. And it's easy to remove, so you can snap it on and off whenever you want.
- Apple Smart - screen cover for tablet
- Product Type
- Screen cover for tablet
- Material
- Polyurethane
- Lavender
- Designed For
- iPad mini 4 (4th generation)
- Material
- Polyurethane
- Lavender
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Cover Type
- Screen cover
- Open Type
- Side
- Cover Features
- Stand function
- Designed For
- Apple iPad mini 4 (4th generation)
