The Magic Keyboard is an amazing companion for iPad Pro and iPad Air. It features an incredible typing experience, a trackpad that opens up new ways to work with iPadOS, a USB-C port for passthrough charging, and front and back protection. The Magic Keyboard has a floating cantilever design, allowing you to attach iPad Pro and iPad Air magnetically and to smoothly adjust it to the perfect viewing angle for you.
- Comfortable backlit keys and a scissor mechanism with 1mm travel for quiet, responsive typing.
- Designed for Multi-Touch gestures and the cursor in iPadOS.
- Smooth angle adjustability delivers the perfect viewing angle.
- USB-C port for charging iPad Pro, freeing up the port on the iPad for other accessories.
- Folds into a case to provide front and back protection for travelling with iPad Pro.
iPad Pro 12.9-inch (3rd, 4th, 5th or 6th generation) running iPadOS 14.5 or later.
iPad Models
- iPad Pro 12.9-inch (6th generation)
- iPad Pro 12.9-inch (5th generation)
- iPad Pro 12.9-inch (4th generation)
- iPad Pro 12.9-inch (3rd generation)
- Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK - white Input Device
- Keyboard and folio case
- Backlit
- Interface
- Apple Smart connector
- Connectivity Technology
- Wired
- Built-in Devices
- Trackpad
- Localization and Layout
- QWERTY UK
- White
- Designed For
- 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation)
- Backlit
- Interface
- QWERTY UK
- Region
- United Kingdom
- Keyboard Technology
- Scissors
- Built-in Devices
- Trackpad
Carrying Case
- Magnetic connection, adjustable viewing angles
- USB-C
- White
- Designed For
- Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation)
