Apple iMac 27-inch with Retina 5K display 3.8GHz quad-core i5
Quicklinx: CXZ4WS00 Mfr#: MNED2B/A
Operating System: Apple macOS Mojave 10.14
Processor Type: Core i5
Installed Memory: 8GB
Hard Drive Capacity: 2TB
Storage Type: Hybrid Drive
  • IEEE 802.11n
  • Core i5
More than 50 in stock
£1,874.17 ex VAT
£2,249.00 inc VAT
A desktop experience that draws you in and keeps you there: this is the idea behind iMac. And now that idea is more powerful. The iMac is packed with impressive graphics technologies, plenty of storage and higher-bandwidth connectivity. And it all comes to life on the brightest and most colorful Retina display. So you get an even more immersive experience - and a scintillating way to take it all in.
  • Performance boosts across the board
    Faster and more powerful, iMac is now equipped with a powerful processor and high-performance graphics. Storage kicks into high gear as well. So you can do everything you love to do on iMac. All at maximum velocity.
  • Graphics that render you speechless
    iMac features powerful graphics that make a spectacle of everything you see. iMac with Retina display is loaded with plenty of dedicated VRAM and delivers visual effects and 3D graphics that exhibit raw power in its most polished form. On top of that, you get advanced video editing capabilities.
  • Accelerate your every move
    Turbo Boost gives you even more power when you're using processor-intensive applications. It all takes place behind the scenes, but you'll see the difference in so many ways.
  • VR for iMac
    VR makes its debut on iMac, with the ability to edit 360° video and create cutting-edge 3D VR content.
  • Brighter than ever
    The Retina display shines even more vividly on the iMac. With one billion colors and 500 nits of brightness, graphics leap off the screen. And the pixel density is so high that you won't detect a single one. Text is so clear and sharp, your email and documents will look smarter than ever.
  • The color you shoot is the color you see
    The world is full of spectacular colors, and iMac brings more of them to your screen. The Retina display uses P3 color that shifts away from standard white LEDs to advanced red-green phosphor LEDs. So all three colors - red, green, and blue - are more equally represented and show off real-world color with more balance and precision.
  • Make some powerful connections
    Two Thunderbolt 3 (USB-C) ports come iMac models, each delivering up to 40Gb/s data transfer for external drives and cameras and twice the bandwidth for video and display connectivity. Four USB 3 ports give you plenty of options for connecting peripherals, including your printer, iPhone, thumb drive, and more. And with ultrafast three-stream Wi-Fi and Bluetooth 4.2 wireless technology, you're instantly connected to all your favorite content.
  • Turn your workspace into a showcase
    Thunderbolt 3 lets you add one 5K display to the amazing one already on your iMac. Or, as another option, you can connect two 4K displays and put over 32 million pixels into play.
  • A lot can happen in 5 millimeters
    An all-in-one computer that puts everything - display, processor, graphics, storage, memory, and more - inside one simple, stylish enclosure. The iMac includes brilliant desktop display and is filled with technologies that take power and performance to another level. Yet it's still just 5 mm thin at its edge.
Apple iMac with Retina 5K display - all-in-one - Core i5 3.8 GHz - 8 GB - 2 TB - LED 27" - English
Personal computer - all-in-one
1 x Intel Core i5 (7th Gen) 3.8 GHz (4.2 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM
Hard Drive
1 x Hybrid Drive 2 TB - SATA
Optical Storage
No optical drive
Card Reader
Monitor
27" - LED - 5120 x 2880 (5K)
Graphics Controller
AMD Radeon Pro 580
Video Memory
8 GB
Camera
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
65 cm x 20.3 cm x 51.6 cm
9.44 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Microphone, stereo speakers
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
4 (Total) / 2 (empty)
Configuration Features
2 x 4 GB
Hard Drive
Hybrid Drive
1 x 2 TB
Interface Type
SATA
Fusion Drive
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
LED - IPS
Diagonal Size
27"
Native Resolution
5120 x 2880 (5K)
Widescreen Display
Image Brightness
500 cd/m²
Monitor Features
LED-backlit
Graphics Controller
Graphics Processor
AMD Radeon Pro 580
Video Memory
8 GB
Audio Output
Sound Output Mode
Stereo
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
HD
FaceTime HD camera
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Apple Magic Keyboard
Wireless
Bluetooth
Localization & Layout
English
Mouse
Mouse Name
Apple Magic Mouse 2
Wireless
Laser
Bluetooth
Multi-Touch
Audio Input
Microphone
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
2 x Thunderbolt 3/DisplayPort/USB-C 3.1 Gen 2 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone
Lightning to USB cable
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power supply
Nominal Voltage
Operating System / Software
OS Provided
Software
Apple iTunes, Apple Mac OS X Mail, Apple iPhoto, Apple iMovie, Apple Safari, Apple GarageBand, Apple Dashboard, Apple Spotlight, Photo Booth, Power Saver, Apple Time Machine, Apple FaceTime, Apple Mission Control, Apple Preview, Maps, Reminders, App Store, Contacts, Notes, Calendar, Apple AirDrop, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, Facebook, Twitter, Family Sharing
ENERGY STAR Certified
65 cm
20.3 cm
51.6 cm
9.44 kg
10 °C
35 °C
5 - 95% (non-condensing)
Apple iMac 27-inch with Retina 5K display 3.8GHz quad-core i5 Bundle deal on Apple iMac 27-inch with Retina 5K display 3.8GHz quad-core i5
£2,056.68
saving £8.33
£1,967.20
Optical Storage: None
Display Size: 27"
Brand: Apple
Price Range Ex VAT: 1500+
