Apple iMac 21.5-inch with Retina 4K display 3.0GHz quad-core i5
Quicklinx: CXYVWS00 Mfr#: MNDY2B/A
Operating System: Apple macOS Mojave 10.14
Processor Type: Core i5
Installed Memory: 8GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i5
  • IEEE 802.11n
Hurry, only 1 left in stock!
£1,040.83 ex VAT
£1,248.99 inc VAT
Faster and more powerful than ever, iMac is now equipped with seventh-generation Intel Core i5 processors and the latest high-performance graphics. Storage kicks into high gear as well, with the speedy and spacious Fusion Drive now available in standard configurations of Retina models. So you can do everything you love to do on iMac.
iMac features powerful Radeon Pro 500 series graphics that make a spectacle of everything you see. The Retina 5K display is loaded with up to 8GB of dedicated VRAM. And Retina 4K display ignites with up to 4GB. Both deliver visual effects and 3D graphics that exhibit raw power in its most polished form. On top of that, you get advanced video editing capabilities. Now you can edit multicam projects in Final Cut Pro X with up to five streams of full-resolution 4K video.
An all-new seventh-generation Intel Core processor in every iMac. And Turbo Boost gives you even more power when you're using processor-intensive applications like Logic Pro or Final Cut Pro. It all takes place behind the scenes, but you'll see the difference in so many ways.
  • Performance boosts across the board
  • Graphics that render you speechless
  • Accelerate your every move
  • Storage that's lightning fast
    Storage is about space. But it's also about speed. A Fusion Drive gives you the best of both worlds. The apps and files you use the most are automatically stored on fast flash storage, while everything else moves to a high-capacity hard drive. From booting up to launching apps to importing photos, it's faster and more efficient to do it all with Fusion Drive.
  • Brighter than ever, more colors than ever
    The Retina display shines even more vividly on the iMac. With one billion colors and 500 nits of brightness, graphics leap off the screen in a light. And the pixel density is so high that you won't detect a single one. Text is so clear and sharp, your email and documents will look smarter than ever. It's simply the best Mac Retina display yet.
  • The color you shoot is the color you see
    The world is full of spectacular colors, and iMac brings more of them to your screen. The Retina display uses P3 color that shifts away from standard white LEDs to advanced red-green phosphor LEDs. So all three colors - red, green, and blue - are more equally represented and show off real-world color with more balance and precision.
  • Double the speed and bandwidth of the previous generation
    Two Thunderbolt 3 (USB-C) ports come standard on all iMac models, each delivering up to 40Gb/s data transfer for external drives and cameras and twice the bandwidth for video and display connectivity. Four USB 3 ports give you plenty of options for connecting peripherals, including your printer, iPhone, thumb drive, and more. And with ultrafast three-stream Wi-Fi and Bluetooth 4.2 wireless technology, you're instantly connected to all your favorite content.
  • Advanced engineering, talk about modern art
    iMac has always been the ultimate in form and function: An all-in-one computer that puts everything - display, processor, graphics, storage, memory, and more - inside one simple, stylish enclosure. The iMac includes the most advanced, most brilliant desktop display we've ever built, and it's filled with all-new technologies that take power and performance to a whole level. Yet it's still just 5 mm thin at its edge
Apple iMac with Retina 4K display - all-in-one - Core i5 3 GHz - 8 GB - 1 TB - LED 21.5" - English
Personal computer - all-in-one
1 x Intel Core i5 (7th Gen) 3 GHz (3.5 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
Hard Drive
1 x 1 TB - SATA - 5400 rpm
Optical Storage
No optical drive
Card Reader
Monitor
21.5" - LED - 4096 x 2304 (4K)
Graphics Controller
AMD Radeon Pro 555
Video Memory
2 GB VRAM
Camera
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
52.8 cm x 17.5 cm x 45 cm
5.66 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Microphone, stereo speakers
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
8 GB / 16 GB (max)
Effective Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Unbuffered
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA
Spindle Speed
5400 rpm
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
LED - IPS
Diagonal Size
21.5"
Native Resolution
4096 x 2304 (4K)
Widescreen Display
Image Brightness
500 cd/m²
Monitor Features
LED-backlit
Graphics Controller
Graphics Processor
AMD Radeon Pro 555
Video Memory
2 GB VRAM
Audio Output
Sound Output Mode
Stereo
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
HD
FaceTime HD camera
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Apple Magic Keyboard
Wireless
Bluetooth
Localization & Layout
English
Mouse
Mouse Name
Apple Magic Mouse 2
Wireless
Laser
Bluetooth
Multi-Touch
Audio Input
Microphone
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
2 x Thunderbolt 3/DisplayPort/USB-C 3.1 Gen 2 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone
Lightning to USB cable
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power supply
Nominal Voltage
Operating System / Software
OS Provided
Software
Apple iTunes, Apple Mac OS X Mail, Apple iPhoto, Apple iMovie, Apple Safari, Apple GarageBand, Apple Dashboard, Apple Spotlight, Photo Booth, Power Saver, Apple Time Machine, Apple FaceTime, Apple Mission Control, Apple Preview, Maps, Reminders, App Store, Contacts, Notes, Calendar, Apple AirDrop, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, Facebook, Twitter, Family Sharing
ENERGY STAR Certified
52.8 cm
17.5 cm
45 cm
5.66 kg
10 °C
35 °C
5 - 95% (non-condensing)
Apple iMac 21.5-inch with Retina 4K display 3.0GHz quad-core i5 Bundle deal on Apple iMac 21.5-inch with Retina 4K display 3.0GHz quad-core i5
£1,227.29
saving £8.33
£1,132.37
Storage Type: HDD
Optical Storage: None
Display Size: 21.5"
Brand: Apple
Price Range Ex VAT: 1000 - 1500
