Grade A returned device
- Can be used on any network
- 12 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Sealed, original packaging
- What’s in the box – iPhone 12 mini and Lighting to USB-C cable are included
5G speed. A14 Bionic, the fastest chip in a smartphone. An edge-to-edge OLED display. Ceramic Shield with four times better drop performance. And Night mode on every camera. iPhone 12 has it all.
5G speed
5G on iPhone is superfast. So you can download movies on the fly. Stream higher-quality video. Or FaceTime in HD over cellular. With lots less lag. And you can do it in more places, because iPhone 12 has the broadest 5G coverage worldwide. -
Trillions operation per second
A14 Bionic pushes what's possible. Like crunching trillions of operations on the Neural Engine. Or shooting in Dolby Vision - even pro movie cameras can't do that. It's superefficient for great battery life. And it's ahead of its time, prepared to power pretty much anything that comes next. -
Super Retina XDR display: behold OLED
Vastly more contrast. Incredible color accuracy. A huge jump in pixel density. OLED delivers brighter brights, darker blacks, and higher resolution for everything you look at. -
Dual-camera system: welcome to the dark side
Both the Wide and Ultra Wide cameras now have Night mode - and it's better than ever at capturing incredible low-light shots. The Wide camera brings in 27 percent more light. So whether you take photos by day or by moonlight, you'll get a level of detail and color that wasn't possible before. -
Video: low lights, camera
How do you improve on the highest-quality video in a smartphone? Make it even better in low light - a full 27 percent better. That means no hour is off limits for more beautifully detailed video. Then there's Night mode Time-lapse. Just prop up your iPhone and let the light trails begin. -
Night mode selfies: you look amazing in the dark
Nighttime is the right time for a selfie. Because Night mode and a slew of other great features are now on the front camera. Like Deep Fusion, Smart HDR 3, Dolby Vision recording, and more. -
Privacy is built in
iPhone is designed to protect your information. Face ID data doesn't leave your iPhone and is never backed up to iCloud or anywhere else. iOS shows you an app's privacy practices before you download it. When you use Apple Pay, your card number isn't shared with merchants. And the list goes on.
- Apple iPhone 12 mini - white - 5G smartphone - 64 GB - CDMA / GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- A2399
- Display
- OLED display - 2340 x 1080 pixels - 5.4" - 476 ppi - Super Retina XDR Display - HDR - fingerprint-resistant oleophobic coating, Ceramic Shield
- Processor
- Apple A14 Bionic (6-core)
- Memory
- 64 GB
- Operating System
- iOS 14
- Main Camera
- 12 Megapixel - wide-angle lens - 2x optical zoom - f/1.6 - focus: automatic
- Second Camera
- 12 Megapixel - ultra wide-angle lens - f/2.4
- Front Camera
- 12 Megapixel f/2.2
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Bluetooth, Wi-Fi 6, UWB
- Security Devices
- Face recognition
- Connectors
- Lightning
- Wireless Charging Standards
- Qi
- Protection
- Dustproof, splashproof, waterproof
- White
- 64.2 mm x 7.4 mm x 131.5 mm
- 133 g
- Repairability Index
- 6.6 (out of 10)
- Specific Absorption Rate (SAR)
- 0.99 W/kg (head) , 0.99 W/kg (body) , 3.85 W/kg (limb)
- 1-year warranty
- Product Type
- Smartphone
- A2399
- Form Factor
- Touch
- Protection
- 64.2 mm
- 7.4 mm
- 131.5 mm
- 133 g
- Body Colour
- White
- Body Material
- Glass, aerospace-grade aluminium
- SAR Value
- 0.99 W/kg (body), 0.99 W/kg (head), 3.85 W/kg (limb)
Cellular
- Technology
- CDMA2000 1X / GSM / WCDMA (UMTS)
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- iOS 14
- Intelligent Assistant
- Siri
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Apple Pay
- Input Device
- Multi-touch, capacitive
Communications
- Data Transmission
- EDGE, EV-DO, HSPA+, DC-HSDPA, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, Gigabit LTE, LAA, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X
- 3G UMTS Band
- Band 1, Band 5, Band 8, Band 10, Band 25
- 3G UMTS Frequency
- 2100, 850, 900, 1700 EAWS, 1900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 30, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 2300 WCS, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n79, n40, n25, n12
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300, FDD 1900, n12
- NFC, Bluetooth 5.0, IEEE 802.11ax, Ultra-Wideband (UWB)
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, 3-axis gyro sensor, digital compass, barometer
- Security Devices
- Face recognition
- Security Technology
- Face ID
- Additional Features
- AirDrop function, Audio zoom function, MIMO technology, Wi-Fi Calling, iBeacon microlocation, QuickType keyboard, Night Shift, Apple TV support (2nd or later), FaceTime audio, Next-generation Neural Engine, Apple MagSafe, Express Transit cards with power reserve, 4K HDR AirPlay Mirroring, FaceTime HD (1080p), RTT/TTY compatible
Media Player
- Supported Digital Audio Standards
- Audible, MP3, FLAC, Apple Lossless, AC-3, AAC-LC, LPCM, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, HE-AAC v2
- Supported Digital Video Standards
- M-JPEG, H.264, HEVC, MPEG-4 Part 2, HEIF
- Video Enhancements
- HDR with Dolby Vision, HDR10
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound
- Apple A14 Bionic
- Processor Core Qty
- 6-core
- Internal Memory Capacity
- 64 GB
Front Camera
- Sensor Resolution
- 12 Megapixel
- Lens Aperture
- F/2.2
- HDR Mode
- Smart HDR 3
- Special Effects
- Natural, Studio, Contour, Stage, Stage Mono, High-Key Mono
- Face Detection
- Face recognition
- Camera Modes
- Burst mode, night mode, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos, Time Lapse (Night mode)
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps
- Light Source
- Retina Flash
- Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, Extended dynamic range for video at 30 fps, QuickTake video, Time-lapse video with stabilisation, Lens correction, Deep Fusion, HDR video recording with Dolby Vision up to 30 fps, Smart HDR 3 with Scene Detection
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.6
- Lens Construction
- 7-element
- Focus Adjustment
- Automatic
- Optical Zoom
- 2x
- Digital Zoom
- 5x
- Special Effects
- Camera Modes
- Burst mode, Panorama, night mode, low-light shots, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos, Time Lapse (Night mode)
- Face Detection
- Face recognition
- HDR Mode
- Smart HDR 3
- Light Source
- True Tone LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- Sapphire crystal lens cover, Cinematic video stabilisation, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, 8MP still photos recording 4K video, Time-lapse video with stabilisation, Slow Sync, Advanced red-eye correction, Optical image stabilization for video, HEIF image capture, Audio zoom, 100% Focus Pixels, Digital zoom up to 3x for video, QuickTake video, HEVC (High Efficiency Video coding), Extended dynamic range for video at 60 fps, Deep Fusion, Smart HDR 3 with Scene Detection, Dolby Vision HDR video recording up to 30 fps
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.4
- Lens Element Qty
- 5-element
- Field of View (FoV)
- 120 degree(s)
- 5-piece lens, Lens correction
Display
- OLED display
- Technology
- Diagonal Size
- 5.4"
- Display Resolution
- Pixel Density
- 476 ppi
- Max Brightness
- 625 cd/m²
- HDR
- HDR Technology
- HDR10
- Enhancement Technology
- Dolby Vision
- Contrast Ratio
- 2000000:1
- Protection
- Fingerprint-resistant oleophobic coating, Ceramic Shield
- Display Languages
- Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English, Australian English, French Canadian, Spanish (Latin American), Chinese (Traditional, Hong Kong), Spanish (Mexican)
- True Tone display, Edge-to-Edge screen, Wide colour display (P3), Haptic touch, Hybrid Log-Gamma (HLG), 1200 nits max brightness (HDR)
- Connector Type
- Lightning
- Technology
- Lithium Ion
- Fast Charging Technology
- Apple fast charging technology, Apple MagSafe wireless charging
- Wireless Charging
- Qi
- Run Time Details
- Playback (video): up to 15 hrs , Playback (streamed video): up to 10 hrs , Playback (audio): up to 50 hrs
- IEC 60529 IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- Lightning to USB-C cable
- Limited warranty - 1 year , Technical support - consulting - 90 days
Sustainability Information
- 6.6 (out of 10)
- Max Depth of Water Resistance
- 6 m
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
Apple Lightning Digital AV Adapter | In Stock | £37.49 |
Apple Lightning to USB Camera Adapter | In Stock | £21.75 |
Apple Lightning to USB Cable (0.5m) | In Stock | £15.00 |
Apple Lightning to USB Cable (2 m) | In Stock | £29.17 |
Apple Lightning to SD Card Camera Reader | In Stock | £26.42 |
Apple EarPods with Lightning Connector | In Stock | £14.34 |
Apple Lightning to 3.5 mm Headphone Jack Adapter | In Stock | £7.21 |
Apple Lightning to USB 3 Camera Adapter | In Stock | £25.39 |
Apple Magic Keyboard with Numeric Keypad - UK Layout | In Stock | £103.71 |
Apple Magic Keyboard with Numeric Keypad | In Stock | £103.71 |
Apple Magic Keyboard with Numeric Keypad - Keyboard - Bluetooth | In Stock | £103.61 |
Apple AirPods - 2nd Generation | In Stock | £95.83 |
Apple 12W USB Power Adapter | In Stock | £15.23 |
Apple MagSafe Charger | In Stock | £35.84 |
Apple AirPods Max - Space Grey | In Stock | £415.84 |
Apple AirPods Max - Silver | In Stock | £415.84 |
Apple AirPods Max - Green | In Stock | £415.84 |
Apple AirPods Max - Sky Blue | In Stock | £415.84 |
Apple AirPods Max - Pink | In Stock | £415.84 |
Apple AirTag | In Stock | £25.00 |
Apple AirTag 4-Pack | In Stock | £99.17 |
Apple AirPods (3rd Gen) with MagSafe Charging Case | In Stock | £140.84 |
Apple USB-C to Lightning Cable (1 m) | In Stock | £14.33 |
Apple Magic Keyboard - British English | In Stock | £79.59 |
Apple USB-C to Lightning Cable 2m | In Stock | £26.59 |
