Apple Apple MagSafe Power Adapter - 85W (MacBook Pro 2010)
Quicklinx: 9HH5WS00 Mfr#: MC556B/C
Device Type: Macbook
Type: Power Adapters
Device Screen Size: [N/A]
Colour: White
£62.32 ex VAT
£74.78 inc VAT
The 85 W MagSafe power adapter features a magnetic DC connector that ensures your power cable will disconnect if it experiences undue strain and helps prevent fraying or weakening of the cables over time. In addition, the magnetic DC helps guide the plug into the system for a quick and secure connection.
When the connection is secure, an LED located at the head of the DC connector will light. An AC cord is provided with the adapter for maximum cord length, while the AC wall adapter gives users an even easier and more compact way to travel.
Designed to be the perfect traveling companion, the adapter has a clever design which allows the DC cable to be wound neatly around itself for easy cable storage.
This power adapter recharges the lithium polymer battery while the system is off, on, or in sleep mode. It also powers the system if you choose to operate without a battery.
Apple MagSafe - power adapter - 85 Watt
Power adapter - external
Power Capacity
85 Watt
MacBook Pro 15" (Mid 2012, Late 2011, Early 2011, Mid 2010); MacBook Pro 17" (Late 2011, Early 2011, Mid 2010)
Power Capacity
85 Watt
Power cable - integrated
Apple Apple MagSafe Power Adapter - 85W (MacBook Pro 2010) Bundle deal on Apple Apple MagSafe Power Adapter - 85W (MacBook Pro 2010)
£161.49
Colour: White
Brand: Apple
Price Range Ex VAT: 50 - 100
