AirPods Pro have been designed to deliver Active Noise Cancellation for immersive sound, Transparency mode so you can hear your surroundings and a customizable fit for all-day comfort. Just like AirPods, AirPods Pro connect like magic to your iPhone or Apple Watch. And they're ready to use straight out of the case.
Incredibly light noise-canceling headphones, AirPods Pro block out your environment so you can focus on what you're listening to. AirPods Pro use two microphones, an outward-facing microphone and an inward-facing microphone, to create superior noise cancellation. By continuously adapting to the geometry of your ear and the fit of the ear tips, Active Noise Cancellation silences the world to keep you fully tuned in to your music, podcasts and calls. -
Transparency mode
Switch to Transparency mode and AirPods Pro let outside sound in, allowing you to hear and connect to your surroundings. Outward- and inward-facing microphones enable AirPods Pro to undo the sound-isolating effect of the silicone tips so things sound and feel natural, like when you're talking to people around you. -
Amazing audio quality
A custom-built high-excursion, low-distortion driver delivers powerful bass. A super-efficient high dynamic range amplifier produces pure, incredibly clear sound while also extending battery life. And Adaptive EQ automatically tunes music to suit the shape of your ear for a rich, consistent listening experience. -
Even more magical
The Apple-designed H1 chip delivers incredibly low audio latency. A force sensor on the stem makes it easy to control music and calls, and switch between Active Noise Cancellation and Transparency mode. Announce Messages with Siri gives you the option to have Siri read your messages through your AirPods. And with Audio Sharing, you and a friend can share the same audio stream on two sets of AirPods - so you can play a game, watch a film or listen to a song together.
- Apple AirPods Pro 1st generation - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Compatibility
- iPhone, iPad, iPod, Mac
- Recommended Use
- Portable electronics
- Additional Functions
- Wireless audio sharing
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Active Noise Canceling
- Controls
- Answer/end, play/pause, next/previous track, audio transparency, ANC on/off
- Intelligent Assistant
- Siri
- Product Type
- True wireless earphones - Bluetooth - wireless
- Product Generation
- 1st generation
- Compatibility
- Dimensions & Weight Details
- Charging case: 6.06 cm x 2.17 cm x 4.52 cm / 45.6 g
- 2.18 cm
- 2.4 cm
- 3.09 cm
- 5.4 g
- Recommended Use
- Protection
- IPX4
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Apple H1 chip
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
Tracking
- Sensors
- Dual optical sensors, motion-detecting accelerometer, speech-detecting accelerometer, force sensor
Internet of Things (IoT)
- Siri
- Included Accessories
- 3 pairs of silicone ear tips, wireless charging case, Lightning to USB-C cable
- Auto On/Off
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 4.5 hour(s)
- Run Time Details
- Continuous playback: up to 4.5 hours , Continuous talk: up to 3.5 hours
Apple Lightning to USB Cable (0.5m) | In Stock | £18.75 |
Apple Lightning to USB Cable (2 m) | In Stock | £29.17 |
Apple Lightning to USB Cable (1m) | In Stock | £17.41 |
Apple MagSafe Charger | In Stock | £35.84 |
Apple USB-C to Lightning Cable 2m | In Stock | £26.59 |
