Click here to access the new BT Shop product sku for Apple Airpods
Wireless. Effortless. Magical.
Just take them out and they're ready to use with all your devices. Put them in your ears and they connect instantly. Speak into them and your voice sounds clear. Introducing AirPods. Simplicity and technology, together like never before. The result is completely magical.
Wireless headphones.
Finally untangled.
After a simple one-tap setup, AirPods are automatically on and always connected. Using them is just as easy. They can sense when they're in your ears and pause when you take them out. And the AirPods experience is just as amazing whether you're listening to your iPhone, Apple Watch, iPad or Mac.
Tap into Siri.
Talking to your favourite personal assistant is a cinch. Just double-tap either AirPod to activate Siri, without taking your iPhone out of your pocket.
What's a chip doing in there? A whole lot.
All the groundbreaking things AirPods can do are driven by the custom-designed Apple W1 chip. It produces extremely efficient wireless for a better connection and improved sound. And the W1 chip manages battery life so well, you can listen for 5 hours on a single charge. It's performance that's unheard of in a device this small.
Knows when you're talking.
A voice accelerometer recognises when you're speaking and works with a pair of beamforming microphones to filter out external noise and focus on the sound of your voice.
Knows when you're listening.
Optical sensors and motion accelerometers work with the W1 chip to automatically control the audio and engage the microphone, giving you the ability to use one or both AirPods. They also enable AirPods to play sound as soon as they're in your ears.
The power of 24 hour battery life.
AirPods deliver an industry-leading 5 hours of listening time on one charge. And they're made to keep up with you, thanks to a charging case that holds multiple additional charges for more than 24 hours of listening time. Need a quick charge? Just 15 minutes in the case gives you 3 hours of listening time. To check the battery, hold the AirPods next to your iPhone or ask Siri "How's the battery on my AirPods?"
Clearly superior sound.
It's great-sounding music, movies and more to your ears. AirPods provide rich, high-quality AAC audio. And when you want to be heard, dual beamforming microphones filter out background noise when you make calls or talk to Siri.
Automatic setup. Seamless switching.
AirPods connect automatically with all your Apple devices. They're simultaneously connected to your iPhone and Apple Watch, and sound switches instantly between the devices. Want to listen to your Mac or iPad? Just choose AirPods on those devices.
What's in the box?
- AirPods
- Charging Case
- Lightning to USB Cable
Wireless headphones
After a simple one-tap setup, AirPods are automatically on and always connected. 1 Using them is just as easy. They can sense when they're in your ears and pause when you take them out. -
Tap into Siri
Talking to your favorite personal assistant is a cinch. Just double-tap either AirPod to activate Siri, without taking your iPhone out of your pocket. -
It's great-sounding music, movies, and more to your ears. AirPods provide rich, high-quality AAC audio. And when you want to be heard, dual beamforming microphones filter out background noise when you make calls or talk to Siri. -
Automatic setup, seamless switching
- Apple AirPods 1st generation - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Compatibility
- iPhone, iPad, iPod, Mac
- Recommended Use
- Portable electronics
- Headphones Form Factor
- Ear-bud
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Controls
- Volume, answer/end, next/previous track
- Product Type
- True wireless earphones - Bluetooth - wireless
- Product Generation
- 1st generation
- Compatibility
- Dimensions & Weight Details
- Charging case: 4.43 cm x 2.13 cm x 5.35 cm / 38 g
- 1.65 cm
- 1.8 cm
- 4.05 cm
- 4 g
- Recommended Use
Audio Output
- Ear-bud
- Connectivity Technology
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
Tracking
- Sensors
- Dual optical sensors, motion-detecting accelerometer, speech-detecting accelerometer
- Included Accessories
- Charging case
- Cable Details
- Lightning cable - detachable
- Auto On/Off
- Battery
- Headphone battery rechargeable
Apple Lightning to USB Cable (0.5m) | In Stock | £15.00 |
Apple Lightning to USB Cable (2 m) | In Stock | £29.17 |
Apple Wireless Charging Case for AirPods | In Stock | £65.84 |
Apple Lightning to USB Cable (1m) | In Stock | £17.30 |
Apple USB-C to Lightning Cable (1 m) | In Stock | £14.33 |
Apple USB-C to Lightning Cable 2m | In Stock | £26.59 |
