Apple AirPods Max - Sky Blue
Quicklinx: G323WS00 Mfr#: MGYL3ZM/A
Connectivity: Wireless
Colours:
£415.84 ex VAT
£499.00 inc VAT
Marketing description is not available.
  • A radically original composition
    The over-ear headphone has been completely reimagined. From cushion to canopy, AirPods Max are designed for an uncompromising fit that creates the optimal acoustic seal for many different head shapes - fully immersing you in every sound. The canopy spanning the headband is made from a breathable knit mesh, distributing weight to reduce on-head pressure. The stainless steel frame is wrapped with a soft-to-the-touch material for a remarkable combination of strength, flexibility, and comfort. Telescoping arms smoothly extend and stay where you set them, for a consistent fit and seal. The beautifully anodized aluminum cups feature a revolutionary mechanism that allows each cup to rotate independently and balance pressure. A custom-designed mesh textile wraps the ear cushions to provide pillow-like softness while listening. Crafted with acoustically engineered memory foam, the ear cushions gently create an immersive seal that is the foundation of incredible sound. The Digital Crown lets you precisely control volume, skip between tracks, answer phone calls, and activate Siri.
  • Sounds like an epiphany
    AirPods Max combine high-fidelity audio with Active Noise Cancellation to deliver an unparalleled listening experience. Each part of their custom-built driver works to produce sound with ultra-low distortion across the audible range. From deep, rich bass to accurate mids and crisp, clean highs, you'll hear every note with a new sense of clarity.
  • Immersive listening
    To cancel unwanted external sound, AirPods Max use a total of six outward-facing microphones to detect noise in your environment, and two inward-facing microphones to measure what you're hearing. Beamforming microphones help isolate your voice on phone calls, so it's heard clearly - even in windy situations.
  • Hear every detail
    The Apple-designed dynamic driver produces a wide frequency range that uncovers the rich details of every sound - delivering your favorite songs with previously unheard texture and accuracy.
  • Distortionless playback
    Modeled after those in high-end floor-standing speakers, the driver's dual-neodymium ring magnet motor minimizes total harmonic distortion across the entire audible range. The result is consistently clear playback, even at full volume.
  • Computational audio - key to performance
    With a powerful Apple-designed H1 chip in each cup, the custom acoustic design, and advanced software, AirPods Max use computational audio to create a breakthrough listening experience. By tapping into each chip's 10 audio cores, computational audio helps block outside noise, adapts audio to the fit and seal of your ear cushions, and makes movie scenes sound like they're happening all around you. The Active Noise Cancellation counters external sound with equal anti-noise, allowing you to immerse yourself in what you're listening to. Press the noise control button to switch to Transparency mode, which lets outside sound in so you can interact naturally with your surroundings. Adaptive EQ tailors sound to the bespoke fit and seal created by the ear cushions. Inward-facing microphones measure what you're hearing, then adjust the frequencies of your music to deliver a rich, consistent experience that faithfully reproduces every note.
  • Spatial audio with dynamic head tracking
    Spatial audio with dynamic head tracking gives you a theater-like experience for movies and shows, with sound that surrounds you. Using built-in gyroscopes and accelerometers, AirPods Max and your iPhone or iPad track the subtle motion of your head, anchoring sounds to your device.
  • Magical experience, elaborately simple
    AirPods Max inherit all of the wireless, effortless magic of the AirPods family. From setup to Siri commands, they make the listening experience completely fluid - day to day, device to device.
  • One-tap setup
    AirPods Max connect immediately to your iPhone or iPad. To pair, simply place AirPods Max near your device and tap Connect on your screen.
  • Seamless switching
    Seamlessly move between your iPhone, iPad, and Mac. If you're playing music on your Mac and take a call on your iPhone, AirPods Max will automatically switch over.
  • Audio Sharing
    Easily share an audio stream between two sets of AirPods on your iPhone, iPad, iPod touch, or Apple TV. Bring any AirPods near the device you're listening to and connect in a tap.
  • On-head detection
    AirPods Max pause audio when you take them off, and resume playback when you put them back on. So you never miss a beat.
  • Announce Messages
    Let Siri speak incoming messages as they arrive with Announce Messages. You can even tell Siri to respond - no hands required.
  • Always-on Siri
    Get directions, check the weather, schedule a meeting, and more with a simple "Hey Siri." With an expansive set of commands, your favorite personal assistant is more helpful than ever.
  • A battery that keeps staying alive
    20 hours of listening, movie watching, or talk time - with Active Noise Cancellation and spatial audio enabled. Simply charge via Lightning connector. A quick 5-minute charge delivering 1.5 hours of listening.
Apple AirPods Max - headphones with mic
Headphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod, Mac
Recommended Use
Portable electronics, computer
Additional Functions
Wireless audio sharing, transparency mode, spatial audio with dynamic head tracking
Sky blue
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Active Noise Canceling
Microphones Included
9
Controls
Volume, play/pause, next/previous track, voice assistant, answer call, ANC/transparency
Intelligent Assistant
Siri
1-year warranty
10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 10.9-inch iPad Air; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iMac; iMac Pro; iPad Air 2; iPad mini; iPad mini 4; 5; iPhone 11, 12, 13, 6s, 7, 8, SE, X, XR, XS, XS Max; Mac mini; MacBook Air; MacBook Pro; TV 4K, HD
Compatibility
Dimensions & Weight Details
Headphones: 16.86 cm x 8.34 cm x 18.73 cm / 384.8 g , Case: 134.5 g
16.86 cm
8.34 cm
18.73 cm
384.8 g
Sky blue
Body Material
Stainless steel, anodised aluminium
Headband Material
Knit mesh
Earpad Material
Memory foam, mesh textile
Recommended Use
On-ear detection
Audio Output
Full size
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Magnet Material
Neodymium magnet
Adjustable Headband
Apple H1 chip
Microphone
Built-in
9
Remote Control
Controls
Tracking
Sensors
Accelerometer, gyro sensor, position sensor, optical sensor, case-detect sensor
Internet of Things (IoT)
Siri
Charging case, Lightning to USB-C cable
Cable Details
USB-C to Lightning cable - detachable
Headphone battery rechargeable
Run Time (Up To)
20 hour(s)
Run Time Details
Continuous playback (active noise-cancelling on): up to 20 hrs , Continuous playback (spatial audio on): up to 20 hrs , Continuous talk: up to 20 hrs
Limited warranty - 1 year
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Early 2021, Late 2012, Late 2013, Late 2014, Late 2015, Mid 2014, Mid 2015, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad Air 2 , Apple iPad mini (6th generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod touch (7G) , Apple Mac mini (Early 2020, Late 2012, Late 2014, Late 2018, Late 2020) , Apple Mac Pro (Late 2013, Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2014, Early 2015, Early 2020, Late 2018, Late 2020, Mid 2012, Mid 2013, Mid 2017, Mid 2019) , Apple MacBook Pro (Early 2013, Early 2015, Early 2020, Late 2012, Late 2013, Late 2016, Late 2019, Late 2020, Mid 2014, Mid 2015, Mid 2017, Mid 2018, Mid 2019) , Apple TV 4K, HD , Apple Watch
G323 Apple Lightning to USB Cable (0.5m) In Stock £18.75
G323 Apple Lightning to USB Cable (2 m) In Stock £29.28
G323 Apple USB-C to Lightning Cable 2m In Stock £31.57
G323 Apple Lightning to USB Cable (1m) In Stock £17.14
Brand: Apple
