Apple 27-inch iMac Pro Retina 5K display 3.0GHz 10-core Intel Xeon W processor 1TB
Quicklinx: FXL2WS00 Mfr#: MHLV3B/A
Operating System: Apple macOS Big Sur 11.0
Processor Type: Xeon W
Hard Drive Capacity: 1TB
Storage Type: SSD
Optical Storage: None
  • IEEE 802.11n
£3,864.60 ex VAT
£4,637.52 inc VAT
Pros love iMac. So Apple created one just for you. It's packed with a powerful processor and graphics, along with advanced storage, memory, and I/O - all behind a breathtaking Retina 5K display in a sleek, all-in-one design. For everyone from photographers to video editors to 3D animators to musicians to software developers to scientists, iMac Pro is ready to turn your biggest ideas into your greatest work.
  • Apple T2 Security Chip: enhanced integration and security
    Every iMac Pro is equipped with the Apple T2 Security Chip, Apple's second-generation custom Mac silicon. By redesigning and integrating several controllers found in other Mac systems - like the system management controller, image signal processor, audio controller, and SSD controller - the T2 Security Chip delivers robust capabilities to the Mac. For instance, the image signal processor works with the FaceTime HD camera to enable enhanced tone mapping, improved exposure control, and face detection-based auto exposure and auto white balance. The T2 also makes iMac Pro even more secure, thanks to a Secure Enclave coprocessor that provides the foundation for encrypted storage and secure boot capabilities. The data on your SSD is encrypted using dedicated AES hardware with no effect on the SSD's performance, while keeping the processor free for your compute tasks. And secure boot ensures that the lowest levels of software aren't tampered with and that only operating system software trusted by Apple loads at startup. The Apple T2 Security Chip also brings a familiar voice to iMac Pro - Hey Siri is always ready to heed your call.
  • Serious I/O for serious work
    As you'd expect from a pro machine, there are plenty of high-speed ports to create a high-performance workstation. Four Thunderbolt 3 ports let you connect two 5K monitors - for 44 million pixels total - and transfer data at a blazing 40Gb/s. And there's something you probably didn't expect in an iMac: 10Gb Ethernet. So sharing files between desktops, or working with high-performance network storage, is up to 10 times faster.
  • Retina 5K display: dream in a billion colors
    It almost goes without saying: If it's an iMac, it will have a gorgeous display. And iMac Pro doesn't disappoint. Its 27-inch Retina screen is crisp and bright, with 500 nits of brightness across its 14.7 million pixels. It's as if the sleek, all-in-one design disappears behind the stunning screen - so you can focus on your content. Along with P3 color and support for a billion colors, iMac Pro delivers spectacular, true-to-life images.
  • All-in-one design: more creative freedom
    iMac Pro puts the power of a workstation behind a stunning Retina 5K display, in a sleek enclosure just 5 mm wide at its edge. With your whole system powered by a single cable, your workspace stays free of clutter. It's a beautifully efficient design that lets you focus all your attention on what you're creating - not what you're creating with.
  • Advanced thermal management
    Packing all that performance into such a slim all-in-one design required a new approach to cooling the system. Apple redesigned the thermal architecture of iMac Pro with innovative dual blowers, a high-capacity heatsink, and extra venting. The result? Almost 75 percent more airflow and an 80 percent increase in system thermal capacity. Which lets iMac Pro handle 500 watts - all while remaining quiet on your desk.
  • Dynamic speakers: make some noise
    The enhanced stereo speakers in iMac Pro deliver broad frequency response, rich bass, and impressive volume. So you'll be able to hear that crashing cymbal, multilayered effect, or sample-based sound, all with remarkable fidelity. And with four beamforming mics, your voice is heard loud and clear over any background noise.
Apple iMac Pro with Retina 5K display - all-in-one - Xeon W 3 GHz - 32 GB - SSD 1 TB - LED 27" - UK - 18 TFLOPS
Personal computer - all-in-one - 18 TFLOPS
Intel Xeon W 3 GHz (4.5 GHz) (10-core)
Processor Main Features
Intel Turbo Boost Technology
Cache Memory
23.75 MB
Cache Per Processor
23.75 MB
RAM
32 GB DDR4 SDRAM - ECC
Hard Drive
SSD 1 TB
Optical Storage
No optical drive
Card Reader
Monitor
27" - LED - 5120 x 2880 (5K)
Graphics Controller
AMD Radeon Pro Vega 56
Video Memory
8 GB HBM2
Camera
Audio Output
Stereo
GigE, 802.11a, 10 GigE, 802.11b/g/n, 802.11ac, 5 GigE, 2.5 GigE, Bluetooth 5.0
Keyboard
OS Provided
Space grey
65 cm x 20.3 cm x 51.6 cm
9.7 kg
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers, 4 microphones
Space grey
Processor / Chipset
CPU
Intel Xeon W 3 GHz
Max Turbo Speed
4.5 GHz
Number of Cores
10-core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
23.75 MB
Cache Per Processor
23.75 MB
RAM
Installed Size
32 GB
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Quad channel memory architecture
Hard Drive
SSD
1 x 1 TB
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Monitor
Monitor Type
LED
Diagonal Size
27"
Native Resolution
5120 x 2880 (5K)
Widescreen Display
Image Brightness
500 cd/m²
Bezel Type
Flat front
Monitor Features
LED-backlit, Wide Colour Gamut, arsenic free
Graphics Controller
Graphics Processor
Video Memory
8 GB HBM2
Floating Point Performance
18 TFLOPS
Performance Details
18 TFLOPS half precision floating point performance, 9 TFLOPS single precision floating point performance
Audio Output
Sound Output Mode
Stereo
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
1080p
FaceTime HD camera
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Apple Magic Keyboard with Numeric Keypad
Wireless
Bluetooth
Localization & Layout
Mouse
Mouse Name
Apple Magic Mouse 2
Wireless
Laser
Bluetooth
Multi-Touch
Audio Input
Four microphones
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, 10 Gigabit Ethernet, IEEE 802.11n, IEEE 802.11ac, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet, Bluetooth 5.0
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
4 x Thunderbolt 3/DisplayPort/USB-C 3.1 Gen 2 , 4 x USB 3.0 , 1 x LAN (10Gigabit Ethernet) , 1 x headphones/microphone
Lightning to USB cable
BFR-free, PVC-free, Beryllium-free, Mercury-free
Power supply
Nominal Voltage
Operating System / Software
OS Provided
Software
Apple iTunes, Apple Mac OS X Mail, Apple iPhoto, Apple iMovie, Apple Safari, Apple GarageBand, Apple Dashboard, Apple Spotlight, Photo Booth, Power Saver, Apple Time Machine, Apple FaceTime, Apple Mission Control, Apple Preview, Maps, Reminders, App Store, Contacts, Notes, Calendar, Apple AirDrop, Siri, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, Facebook, Twitter, Family Sharing
65 cm
20.3 cm
51.6 cm
9.7 kg
10 °C
35 °C
5 - 95% (non-condensing)
Sound Emission
13 dBA
Storage Type: SSD
Brand: Apple
Price Range Ex VAT: 1500+
