Apple 16-inch MacBook Pro w/Touch Bar 2.3GHz i9 1TB - Silver
Quicklinx: FJ86WS00 Mfr#: MVVM2B/A
Display Size: 16in
Operating System: Apple macOS Catalina 10.15
Installed Memory: 16GB
Hard Drive Capacity: 1TB
Optical Storage: None
  • IEEE 802.11n
More than 50 in stock
£2,062.70 ex VAT
£2,475.24 inc VAT
The thermal architecture in MacBook Pro has been completely redesigned, featuring larger impellers with improved fan blades for optimal airflow and more heat-dispersing fins for more effective cooling. The resulting gain in cooling capacity allows MacBook Pro to deliver up to 12 watts more maximum sustained power.
MacBook Pro has a big voice. The six-speaker sound system produces room-filling wide stereo sound like you've never heard from a notebook before. Dual force-canceling woofers dramatically reduce system vibration for a clearer, more natural sound and a half-octave lower range to the bass. And the studio-quality three-mic array rivals professional third-party microphones, for creating superclean podcasts or music recordings on the go.
  • A big, beautiful workspace
    The MacBook Pro features a stunning 16-inch Retina display. It produces 500 nits of brightness for spectacular highlights and bright whites, while delivering deep blacks thanks to the precise photo alignment of liquid crystal molecules. And the P3 wide color gamut enables brilliant, true-to-life images and video.
  • Working at the speed of thought
    Thanks to a more advanced thermal design, the powerful processor with up to 8 cores and 16 threads of processing power sustains higher performance for longer periods of time - and delivers up to 2.1 times the performance of a quad-core MacBook Pro. So whether you're layering dozens of tracks and effects, rendering 3D models, or compiling and testing code, you'll be doing it in no time flat.
  • More advanced thermal architecture enables faster processing
  • Bending reality takes bandwidth
    The 16-inch MacBook Pro base model is over two times faster than the previous-generation base model, for seamless playback and faster rendering of ultra-high-definition video.
  • There's magic in a perfect workspace
    The Magic Keyboard features a refined scissor mechanism with 1 mm travel for a responsive, comfortable, and quiet typing experience. The Touch Bar puts powerful shortcuts front and center, and Touch ID provides fast authentication. A dedicated Escape key allows quick switching between modes and views. And the inverted-T arrow keys enable fluid navigation whether you're flying through lines of code, navigating spreadsheets, or gaming.
  • Bigger bass, better mic
  • Thunderbolt 3
    Thunderbolt 3 combines ultra-high bandwidth with the ultra-versatility of the USB-C industry standard to create one revved-up universal port. It integrates data transfer, charging, and video output in a single connector, delivering up to 40Gb/s of throughput for twice the bandwidth of Thunderbolt 2. MacBook Pro is equipped with four ports, so you can do all of that from either side. Existing devices are easily connected with a cable or adapter. And Thunderbolt 3 is reversible, so no matter how you plug in, it's always right side up.
Apple MacBook Pro with Touch Bar - 16" - Core i9 - 16 GB RAM - 1 TB SSD - UK
Notebook
Operating System
Intel Core i9 (9th Gen) 2.3 GHz (4.8 GHz) / 16 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
1 TB SSD
Optical Drive
No optical drive
Display
16" LED backlight 3072 x 1920 - 226 ppi
Graphics
AMD Radeon Pro 5500M / Intel UHD Graphics 630
Video Memory
4 GB GDDR6 SDRAM
Input Device
Force Touch trackpad, Touch Bar
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Up to 11 hours
Security
Apple T2 Security Chip, fingerprint reader
Silver
35.79 cm x 24.59 cm x 1.62 cm
2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
SAR
0.82 W/kg (body)
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4.8 GHz
Number of Cores
8-core
Cache
L3 - 16 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2666 MHz
Storage
Main Storage
1 TB SSD - (soldered)
Display
16" - IPS
LCD Backlight Technology
LED backlight
Resolution
3072 x 1920
Widescreen
Pixel Density (ppi)
226
Image Brightness
500 cd/m²
Bezel Type
Flat front
BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free, Retina display, True Tone display, 60 Hz refresh rate, P3 Wide Color Gamut
Keyboard Name
Apple Magic Keyboard
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR6 SDRAM
Camera
Yes - 720p
Camera Features
FaceTime HD camera
Sound
Six speakers, three microphones
Dolby Atmos
Input
Keyboard, Force Touch trackpad, Touch Bar
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
Wireless
Lithium polymer
100 Wh
Run Time
Up to 11 hours
Battery Run Time
Web browsing over Wi-Fi: up to 11 hours , Video playback: up to 11 hours , Standby time: up to 30 days
AC Adapter
Input
Output
96 Watt
Connections & Expansion
4 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery) , Headphone output
Software
Software Included
Drivers & Utilities, Apple QuickTime, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Dictation, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My
Silver
Case Material
Aluminum
Security
USB-C power adapter
USB-C charge cable
SAR Value
0.82 W/kg (body)
Localization
2 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
Display Size: 16in
Graphics: AMD Radeon Pro 5500M / Intel UHD Graphics 630
Hard Drive Type: SSD
Brand: Apple
Price Range Ex VAT: 1500+
